Making a 914-6 Conversion your own, The Quest for Quiet |
Root_Werks |
Nov 27 2024, 04:26 PM
Village Idiot Group: Members Posts: 8,492 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
The Six Conversion:
2.7 CIS with 993 cams, 46/40 valves, 911S 8.5:1 CIS Pistons with Nikasil cylinders. Guessing it produces slightly more than stock 2.7S HP and has a much lower, broader TQ curve. Current exhaust is stock 914-6 HE's and one of Ben's SS Quiet mufflers. Been very happy with the exhaust note the past few years, but always wondered if stock would be quieter. Ben's Quiet Muffler ( I did have to reclock the tip as it was more for 1974-up 911): Attached thumbnail(s) |
Root_Werks |
Nov 27 2024, 04:38 PM
Ran the same tests as close as I could, same stretches of road and highway, windows up, same gears etc.
Dansk muffler results: Idle outside - 80 Idle inside - 67 30mph - 77 4th gear 60mph - 85 5th gear 70mph - 87 5th gear As the DB goes, not much of a difference by the numbers. Although I could tell on the freeway the note was toned down a bit. Was it worth it? Eh, probably not. Not really much of a difference in overall cabin noise and I gained back that 5-6lbs right on the tail of the 914 (Dansk is heavier than SS). Not sure if I'll swap back to the SS or not. I do like how the Dansk is hidden a little better. Next steps to queit the cabin down: Pull the rear window and swap out for safety glass version. I did this once many years ago on a 914-4 and was shocked how much engine noise was deadened. Also noticed I need to adjust my rear trunk stop on the Left side. Attached thumbnail(s) |
worn |
Nov 27 2024, 04:55 PM
can't remember Group: Members Posts: 3,356 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
When I first got the 3.2 engine in the car I decided to cut up the 911 muffler that came with the motor using an article in Upfixing Der Porsche as a guide. Fit it to MSDS headers. Over time I had a loss in faith about my own handiwork and swapped out the homemade muffler for a very pretty Dansk sausage. Net result was, eh. I couldn’t hear or feel much of a difference. The only positive was that I no longer worry about doing it wrong.
Lo-Fi Version | Time is now: 4th December 2024 - 08:35 PM |
