Shifter Cone Screw Keeps Loosening, Thread Locker or Worn? |
Spoke |
Dec 6 2024, 07:30 AM
Jerry Group: Members Posts: 7,104 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Every 6 months I have to retighten the cone screw on the shifter. This time it came out real quick. I thought it might come out all together. I couldn't get 2nd without hitting reverse. The picture shows how much the screw backed out.
Not sure how much torque I applied but I was bending the allen wrench. Questions: Should I have thread locker on this? What is the torque required for the cone screw? Possible that the threads have been widened by repeated looseness? Why didn't they put a bolt through this to really lock the hub onto the shaft? TIA (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
Spoke |
Dec 6 2024, 08:03 AM
The cone screw thread appears to be folded over at the bottom. Really messed up.
Attached image(s) |
87m491 |
Dec 6 2024, 09:25 AM
Member Group: Members Posts: 326 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
The cone screw thread appears to be folded over at the bottom. Really messed up. Indeed, also the first of your 2 pix shows a void in the threads where a silicone anti vibration, anti backout slug, would be sitting in a new factory screw. Both of those items likely causing you backing out. |
Lo-Fi Version | Time is now: 27th December 2024 - 11:18 AM |
