> Shifter Cone Screw Keeps Loosening, Thread Locker or Worn?
Spoke
post Dec 6 2024, 07:30 AM
Jerry
Every 6 months I have to retighten the cone screw on the shifter. This time it came out real quick. I thought it might come out all together. I couldn't get 2nd without hitting reverse. The picture shows how much the screw backed out.
Not sure how much torque I applied but I was bending the allen wrench.
Questions:
Should I have thread locker on this?
What is the torque required for the cone screw?
Possible that the threads have been widened by repeated looseness?
Why didn't they put a bolt through this to really lock the hub onto the shaft?
TIA
GregAmy
post Dec 6 2024, 11:49 AM
I know it's often said these are one-use items, but there's nothing with the threads that would support that contention, other than new ones come with a dab of loctite (or similar) on them.
In my case I clean the hell out of the threads (usually brake clean) and dab with blue loctite (I use the semi-solid "Quickstix" dispenser version) and - knock on wood - I've never had a problem in either car. And they're part of a standard underside inspection every oil change.
But that one with the buggered threads? Nope. And that may have buggered the aluminum casting in the process.
Spoke   Shifter Cone Screw Keeps Loosening   Dec 6 2024, 07:30 AM
brant   Intended to be one time use Replace both. And you...   Dec 6 2024, 07:33 AM
JamesM   Intended to be one time use Replace both. And yo...   Dec 7 2024, 07:40 PM
Spoke   The cone screw thread appears to be folded over at...   Dec 6 2024, 08:03 AM
Superhawk996   The cone screw thread appears to be folded over a...   Dec 6 2024, 08:33 AM
87m491   The cone screw thread appears to be folded over a...   Dec 6 2024, 09:25 AM
Superhawk996   Why didn't they put a bolt through this to r...   Dec 6 2024, 08:29 AM
Steve   Unless their worn or partially stripped, I just pu...   Dec 6 2024, 08:55 AM
VaccaRabite   A small amount of blue loctite is all you need. T...   Dec 6 2024, 09:02 AM
Superhawk996   A small amount of blue loctite is all you need. ...   Dec 6 2024, 09:22 AM
930cabman   A small amount of blue loctite is all you need. ...   Dec 6 2024, 10:50 AM
ejm   First time I've seen a cone screw facing up. I...   Dec 6 2024, 11:14 AM
930cabman   First time I've seen a cone screw facing up. ...   Dec 6 2024, 12:52 PM
r_towle   First time I've seen a cone screw facing up. ...   Dec 9 2024, 07:30 PM
Spoke   First time I've seen a cone screw facing up....   Dec 9 2024, 07:47 PM
rjames   I don't know what the exact spec is, but it...   Dec 6 2024, 11:44 AM
GregAmy   I know it's often said these are one-use items...   Dec 6 2024, 11:49 AM
Spoke   I cleaned up the first thread on the cone nut and ...   Dec 6 2024, 12:26 PM
flipb   If you want to replace the coupler, the part numbe...   Dec 6 2024, 03:26 PM
mb911   Every 6 months I have to retighten the cone screw...   Dec 7 2024, 07:20 AM
DC_neun_vierzehn   This is the cheapest I've found the Genuine Po...   Dec 7 2024, 08:42 AM
Bartlett 914   I reuse mine. I use a torch and warm the screw. Yo...   Dec 7 2024, 08:43 AM
930cabman   I reuse mine. I use a torch and warm the screw. Y...   Dec 7 2024, 09:39 AM
Bartlett 914   I reuse mine. I use a torch and warm the screw. ...   Dec 7 2024, 01:30 PM
brant   I've salvaged knuckles in the past... take the...   Dec 7 2024, 08:43 AM
rhodyguy   That’s why you buy 4 at a time. They fit in the ...   Dec 7 2024, 02:14 PM
sixnotfour   I wish they still had the square head with lock wi...   Dec 7 2024, 06:24 PM
SKL1   Thanks for the part numbers! Think I'll o...   Dec 7 2024, 09:13 PM
913B   I remember there was a vendor that had a modified ...   Dec 8 2024, 12:45 PM
Spoke   Problem solved. Sort of. At least I can move the c...   Dec 9 2024, 10:11 PM
930cabman   Problem solved. Sort of. At least I can move the ...   Dec 10 2024, 11:18 AM
Spoke   Side note, how is progress with your 930? The t...   Dec 10 2024, 03:07 PM
TheCabinetmaker   Your coupler is on upside down. Get a new coupler ...   Dec 10 2024, 10:35 AM
930cabman   Your coupler is on upside down. Get a new coupler...   Dec 10 2024, 11:17 AM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 11:25 AM
