Shifter Cone Screw Keeps Loosening, Thread Locker or Worn? |
Spoke |
Dec 6 2024, 07:30 AM
Jerry Group: Members Posts: 7,104 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Every 6 months I have to retighten the cone screw on the shifter. This time it came out real quick. I thought it might come out all together. I couldn't get 2nd without hitting reverse. The picture shows how much the screw backed out.
Not sure how much torque I applied but I was bending the allen wrench. Questions: Should I have thread locker on this? What is the torque required for the cone screw? Possible that the threads have been widened by repeated looseness? Why didn't they put a bolt through this to really lock the hub onto the shaft? TIA (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
Bartlett 914 |
Dec 7 2024, 08:43 AM
Advanced Member Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I reuse mine. I use a torch and warm the screw. You will see the plastic ball soften. It will come out easily. I then insert a 1/8" nylon ball n place. A drop of instant adhesive will hold in in place. When inserting the screw, some will be cut off. You may think it all came out but it hasn't. I have done this for yr\ears. McMaster Carr will sell 100 1/8" nylon balls for less than a single cone screw. I have done this for years and no issues!
930cabman |
Dec 7 2024, 09:39 AM
Advanced Member Group: Members Posts: 3,780 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I reuse mine. I use a torch and warm the screw. You will see the plastic ball soften. It will come out easily. I then insert a 1/8" nylon ball n place. A drop of instant adhesive will hold in in place. When inserting the screw, some will be cut off. You may think it all came out but it hasn't. I have done this for yr\ears. McMaster Carr will sell 100 1/8" nylon balls for less than a single cone screw. I have done this for years and no issues! May I nominate you sir for CSOB of the year? (IMG:style_emoticons/default/beer.gif) |
Bartlett 914 |
Dec 7 2024, 01:30 PM
I reuse mine. I use a torch and warm the screw. You will see the plastic ball soften. It will come out easily. I then insert a 1/8" nylon ball n place. A drop of instant adhesive will hold in in place. When inserting the screw, some will be cut off. You may think it all came out but it hasn't. I have done this for yr\ears. McMaster Carr will sell 100 1/8" nylon balls for less than a single cone screw. I have done this for years and no issues! May I nominate you sir for CSOB of the year? (IMG:style_emoticons/default/beer.gif) Thanks. But cheap isn't it. Shipping delay also plays a part. I never need to wait on one. |
Lo-Fi Version | Time is now: 27th December 2024 - 11:33 AM |
