> Question about early vs. late tops
DC_neun_vierzehn
post Dec 7 2024, 02:07 PM
I know there are two different tops (early vs. late).
My question is can an early top work on a late car IF the rubber seals on the sides have been updated (to match the late windows) AND the bump stops have been swapped (to match the late latches)?
The reason I ask is that I have two spare tops (one early and one late). I have them both stripped down (no rubber, no hardware, no felt headliner, etc.). Just the fiberglass top. And I noticed that the early top much lighter. I weighed them and the early top is approx. 17 pounds whereas the late top is approx. 23 pounds.
I'm not looking to shed weight for performance (although that's a bonus), but a lighter top would be less cumbersome to take off and put on the car.
TIA
-Kris
JamesM
post Dec 7 2024, 07:34 PM
While there are changes to the roof itself and the only difference as far as fitment goes is related to the rear rubber block/latches, and those are swappable. As long as you make sure the rear rubber stand offs used match the rear latches used you should be fine.
As illustrated in the posted link the rear blocks have a taller narrower version and a shorter wider version. What isnt shown in that thread is that there are 2 different rear Targa latches that correspond with the different rubber blocks one version is shallower in depth with wider alignment bumps and the other is deeper with the alignment bumps closer together. A mismatch of these components is what causes poor Targa fitment.
DC_neun_vierzehn   Question about early vs. late tops   Dec 7 2024, 02:07 PM
930cabman   :popcorn:   Dec 7 2024, 02:52 PM
DC_neun_vierzehn   :popcorn: One of the things I’ve loved about ...   Dec 7 2024, 05:48 PM
Robarabian   That reply was pretty normal actually... someone i...   Dec 7 2024, 06:44 PM
930cabman   :popcorn: One of the things I’ve loved about...   Dec 8 2024, 02:01 PM
DC_neun_vierzehn   [quote name='DC_neun_vierzehn' post='3180689' dat...   Dec 8 2024, 02:45 PM
930cabman   [quote name='DC_neun_vierzehn' post='3180689' da...   Dec 8 2024, 03:36 PM
SirAndy   More than you ever wanted to know. http://www.914w...   Dec 7 2024, 06:19 PM
DC_neun_vierzehn   More than you ever wanted to know. http://www.914...   Dec 7 2024, 06:45 PM
SirAndy   [quote name='SirAndy' post='3180693' date='Dec 7 ...   Dec 7 2024, 08:21 PM
JamesM   Not only are the seals different, the actual mou...   Dec 7 2024, 09:21 PM
SirAndy   Not only are the seals different, the actual mo...   Dec 7 2024, 09:53 PM
JamesM   Not only are the side seals different but the ch...   Dec 8 2024, 08:23 PM
fixer34   FWIW, I did the exact opposite to my '70 over ...   Dec 7 2024, 06:26 PM
JamesM   While there are changes to the roof itself and the...   Dec 7 2024, 07:34 PM
cgnj   @DC_neun_vierzehn I have a 1970 top, a 73 914 wit...   Dec 7 2024, 10:12 PM
DC_neun_vierzehn   @[url=http://www.914world.com/bbs2/index.php?show...   Dec 8 2024, 09:34 AM
DC_neun_vierzehn   I just laid down both naked tops (no hardware, no ...   Dec 10 2024, 03:08 PM
930cabman   I just laid down both naked tops (no hardware, no...   Dec 10 2024, 05:06 PM
SirAndy   I just laid down both naked tops (no hardware, no...   Dec 10 2024, 05:19 PM
JamesM   :idea: On mine (late top, early doors), i had ...   Dec 11 2024, 01:11 AM
Literati914   Not only are the side seals different but the c...   Dec 12 2024, 09:39 AM
- Lo-Fi Version Time is now: 27th December 2024 - 10:40 AM
