Question about early vs. late tops |
DC_neun_vierzehn |
Dec 7 2024, 02:07 PM
Member Group: Members Posts: 485 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
I know there are two different tops (early vs. late).
My question is can an early top work on a late car IF the rubber seals on the sides have been updated (to match the late windows) AND the bump stops have been swapped (to match the late latches)? The reason I ask is that I have two spare tops (one early and one late). I have them both stripped down (no rubber, no hardware, no felt headliner, etc.). Just the fiberglass top. And I noticed that the early top much lighter. I weighed them and the early top is approx. 17 pounds whereas the late top is approx. 23 pounds. I'm not looking to shed weight for performance (although that's a bonus), but a lighter top would be less cumbersome to take off and put on the car. TIA -Kris |
DC_neun_vierzehn |
Dec 10 2024, 03:08 PM
I just laid down both naked tops (no hardware, no seals, nothing - just the bare fiberglass. Everything measured the same on the sides - the holes where the screws mounted the rails for the side window seals was identical on both. I'm going to remount the rails to see if those also measure the same.
If they do, then it's just the rubber side window seals and rubber bump stops (and corresponding latches) that materially changed in terms of fitment and therefore they should be able to be swapped if the seals and bump stops (and corresponding latches) were swapped out. |
Lo-Fi Version | Time is now: 27th December 2024 - 09:53 AM |
