> Setting deck height for 9:1 compression
Chad911sc
post Dec 11 2024, 04:46 PM
I have my short block built and I’m ready to set my deck height. It’s 96mm bore with stock 71mm factory crank. This is a 2.0 2056 build. I have a Web 86a cam calling for approx 9:1 compression. I have 60cc heads with 3cc valve reliefs on my flat top pistons. If I plug all this into the calculator, I get 8.3:1 for my compression ratio if I set the deck height to .040 inch
After I set up the piston on the rod and bolt down the cylinder to the block, I get .053 inch from the piston to the top of the cylinder.
My question is, what is the best way to proceed to get the 9:1 ratio with at least .040 inch total deck height.
I am thinking that if I take off 6 total cc’s from the head, that will leave me with 54cc heads with the 3cc valve pocket = total 57cc’s. Bringing me now to the correct 9:1 compression ratio with the .040 inch deck height.
If I am in the right ballpark, this means I need to have my heads fly cut….correct??
If this is correct, how do I go about calculating how many thousands of an inch do I need to have removed by the machine shop to remove 6cc from the head?
I obviously will need to remove at least .013 inch total deck height get to my .040 goal, and that’s with no shims or head gaskets being used.
Thanks for your time, Chad
technicalninja
post Dec 19 2024, 03:20 PM
The case line SHOULD be centered but...
Where it matters is a center axis of the crankshaft.
This is how shit can go wrong...
One of my other projects is a 91 MR2 Turbo.
After tearing the stock gen 2 engine down (all OK, just never touched and OLD) a built Gen 3 engine showed up on Craigslist here in DFW.
This engine was out of a wrecked car and it was cheap!
Gen 3 engines are SHITLOADS better. They never made it to the USA and this one was seriously built ($10,000 receipt). H-beams, Wisecos, billet cams, adjustable cam gears, whole list of good shit.
I went to look. Took a borescope and leak down stuff.
Minor vertical scoring lines in the bore surface. It had been run an extended time without an airfilter!
Leak downs sucked. All the valves had leakage and "bonking" them didn't improve it much.
It HAD been sitting 9 months.
I bought it for half what he was asking...
The receipt was from a well known shop who specialized in these.
I've purchased many things from them.
So, I've got this bad-assed 2.0l that needs a ring job and cleaning up the valves.
I rip it apart. Check deck height on all 4. I've learned to do this early instead of late.
.006 difference in deck height!!!!!! (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
I'm used to seeing deck height difference BELOW .001. I'm expecting "tenths" and have results that are HUGE!
I'm PISSED!
What I found, after swapping rods/pistons and then installing the crank out of my gen2 in it was two things.
#4 rod bearing journal was repaired via "off-set" grinding (this is a NORMAL thing for quicky machine shop repair) and the deck seemed to be ground at an angle to the crank.
I told the machine shop what I thought, and Eric documented what they found.
It took .0017" to clean it up. He did a final cut at 2 thousands. It WAS decked at an angle!
The crank journal was off-set ground right at .005"
I used the Gen 2 crank out of the car's original engine (never been machined and not damaged at all). Had it micro-polished/balanced and put it back together.
Deck height differences are .0003 now!
The shop in question is NOT a machine shop. They sub the work out
They OBVIOUSLY didn't check anything when they got it back.
The machine shop in question did a "quick production" job on the crank and they decked it from the oil pan registers instaead of the crank bore.
This is the FASTER way to complete the machine work and everything would have worked absolutely fine on a bone stock build at 200hp.
This build is targeted for 500hp (which as actually conservative) and that level of variation is unacceptable at that power level.
So, on another active build at 2.0L I'm shooting for 500 hp.
And parts for that puppy are CHEAPER than T4 stuff...
Chad911sc   Setting deck height for 9:1 compression   Dec 11 2024, 04:46 PM
Chad911sc   I have my short block built and I’m ready to set...   Dec 11 2024, 04:49 PM
technicalninja   You're on the right track. Altering the cylin...   Dec 11 2024, 05:36 PM
930cabman   top of then cylinders MUST be in plane with each o...   Dec 11 2024, 06:24 PM
Shivers   You need to raise the compression, right? If so yo...   Dec 11 2024, 06:29 PM
cgnj   Was your case decked? Did you check the volume of ...   Dec 12 2024, 12:14 AM
Chad911sc   Thanks for the replies! I did cc the heads and...   Dec 12 2024, 09:38 AM
rfinegan   Yes Get your deck hight sorted first... Then set t...   Dec 12 2024, 10:31 AM
technicalninja   Thanks for the replies! I did cc the heads an...   Dec 12 2024, 11:08 AM
930cabman   Thanks for the replies! I did cc the heads a...   Dec 12 2024, 01:27 PM
Chad911sc   Very true!! I actually watched all of Ianâ...   Dec 12 2024, 02:05 PM
Chad911sc   Spent the day on your recommendation to resurface ...   Dec 14 2024, 02:10 PM
Jack Standz   This should work fine for a shade tree mechanic re...   Dec 14 2024, 03:13 PM
iankarr   All great advice. Glad you found the videos helpfu...   Dec 14 2024, 05:19 PM
Jack Standz   I'd assume that your decks aren't flat, no...   Dec 15 2024, 11:50 AM
Jack Standz   One more thought. Raby in this video says that g...   Dec 15 2024, 12:19 PM
technicalninja   :agree: Jack is right! Someone (maybe Jack ...   Dec 15 2024, 02:33 PM
Chad911sc   Thanks for all the replies! Wish I would have ...   Dec 16 2024, 02:39 PM
Superhawk996   They were both at .053 before the lapping and now...   Dec 17 2024, 09:21 AM
seanpaulmc   A guy local to me rebuilding his 912 built up a 22...   Dec 17 2024, 07:50 AM
Chad911sc   Awesome! Thanks Sean! I’ve heard of Rev ...   Dec 17 2024, 09:46 AM
seanpaulmc   Okay, so where is the build thread? As you may no...   Dec 17 2024, 06:52 PM
Chad911sc   So I have the case halves back apart and now just ...   Dec 18 2024, 01:17 PM
Chad911sc   I think I figured it out with my daughters help…...   Dec 18 2024, 01:32 PM
Chad911sc   This is the 74 914 that it is going into…one of ...   Dec 18 2024, 01:37 PM
Chad911sc   Question…. When I get my heads fly cut, it looks...   Dec 18 2024, 09:59 PM
technicalninja   On a bone stock 73 2.0l the depression in the head...   Dec 18 2024, 10:50 PM
Jack Standz   So I have the case halves back apart and now just...   Dec 19 2024, 07:15 AM
Chad911sc   I understand what you are saying about the deck pa...   Dec 19 2024, 08:41 AM
technicalninja   I understand what you are saying about the deck p...   Dec 19 2024, 10:37 AM
Jack Standz   I, personally, don't believe EVERYTHING Jake...   Dec 19 2024, 12:15 PM
Chad911sc   Thanks guys! Now worries, no offense taken. Li...   Dec 19 2024, 01:12 PM
rfinegan   duplicated   Dec 19 2024, 02:27 PM
rfinegan   Am I missing something... Machine the case to the ...   Dec 19 2024, 02:33 PM
technicalninja   The case line SHOULD be centered but... Where it ...   Dec 19 2024, 03:20 PM
rfinegan   great follow up. Thanks for the information   Dec 19 2024, 03:34 PM
technicalninja   The 911 is COOL! What's that white car in...   Dec 19 2024, 04:26 PM
Jack Standz   Chad, Awesome looking 911SC. You should be worki...   Dec 19 2024, 08:33 PM
Chad911sc   The 911sc is actually a Max Moritz built Porsche. ...   Dec 20 2024, 09:11 AM
technicalninja   Let's see here... 500 hp Vette Nice NICE NICE...   Dec 20 2024, 01:26 PM
- Lo-Fi Version Time is now: 21st December 2024 - 07:43 PM
