Setting deck height for 9:1 compression |
Chad911sc |
Dec 11 2024, 04:46 PM
Newbie Group: Members Posts: 21 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States |
I have my short block built and I’m ready to set my deck height. It’s 96mm bore with stock 71mm factory crank. This is a 2.0 2056 build. I have a Web 86a cam calling for approx 9:1 compression. I have 60cc heads with 3cc valve reliefs on my flat top pistons. If I plug all this into the calculator, I get 8.3:1 for my compression ratio if I set the deck height to .040 inch
After I set up the piston on the rod and bolt down the cylinder to the block, I get .053 inch from the piston to the top of the cylinder. My question is, what is the best way to proceed to get the 9:1 ratio with at least .040 inch total deck height. I am thinking that if I take off 6 total cc’s from the head, that will leave me with 54cc heads with the 3cc valve pocket = total 57cc’s. Bringing me now to the correct 9:1 compression ratio with the .040 inch deck height. If I am in the right ballpark, this means I need to have my heads fly cut….correct?? If this is correct, how do I go about calculating how many thousands of an inch do I need to have removed by the machine shop to remove 6cc from the head? I obviously will need to remove at least .013 inch total deck height get to my .040 goal, and that’s with no shims or head gaskets being used. Thanks for your time, Chad |
Chad911sc |
Dec 20 2024, 09:11 AM
The 911sc is actually a Max Moritz built Porsche. It was bought in Germany by a space engineer that ended up moving to Florida and bringing it with him. She is my baby and as you said deserves to be back on the road. I just get distracted by a new project way too easily…lol.
The white car in the background is a 69 Opel GT that I ended up building a 347 ford stroker motor for and had a 4:10 posi shortened rear end into. That was one of the parts cars I used to steal panels from to fix the other one that’s not in the picture. |
Lo-Fi Version | Time is now: 21st December 2024 - 08:15 PM |
