2.0 build to 2056 or 2270?, Which cam would be best ?? Going carburetorated, with 96mm pistons |
zman914 |
Dec 20 2024, 06:02 PM
Newbie Group: Members Posts: 5 Joined: 25-July 23 From: Vacaville, ca Member No.: 27,483 Region Association: Northern California |
Looking to do a 2056 or 2270 build from a stock 2.0. Changing over to carburetorated, with 96mm pistons.. Looking for good cam advise. I'm looking for more hp, but very reliable.
JamesM |
Dec 21 2024, 06:22 PM
Advanced Member Group: Members Posts: 2,019 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Looking to do a 2056 or 2270 build from a stock 2.0. Changing over to carburetorated, with 96mm pistons.. Looking for good cam advise. I'm looking for more hp, but very reliable. All cams except for stock are good, but which one you want depends on your goals and the specifics of your setup. Are you looking for bottom or top end? How high are you looking to rev it? Do you want something tame or more exciting? What sort of heads/porting/valve sizes are you using? What does your exhaust setup look like? What carbs are you running? |
Lo-Fi Version | Time is now: 22nd December 2024 - 02:04 AM |
