bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,849 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Warning : Adding shims reduces the number of engaged threads of the 10mm attaching bolts. The stock length of the 10mm bolts is 55mm. If you have a shim pack more than 5mm use new longer 10.9 grade 10 mm bolts. I recently shimmed a 914 to correct the excessive rear camber. One side had about 10mm in shims before adding 3mm more in shims. We had four threads of engagement of the trailing bolts after adding more shim pack. We changed to 70 mm bolts. The other side had a shorter shim pack and the 70mm bolts bottomed out on the non threaded portion of the bolt. 65mm bolts worked.
I had a new batch of stainless steel rear alignment shims in 1, 2, and 3mm thicknesses. Standard shims are 2, 3, an 4mm thick. This assortments easily allows for 1mm increments of adjustment. Any three shims for $35 or 6 for $60 shipped-. each group will include 6 new Schnoor washers as they need to be replaced if the bolts are loosened. \ @technicalninja @FlacaProductions @racer914 Attached thumbnail(s) ![]() ![]() |
sixaddict |
Senior Member ![]() ![]() ![]() Group: Members Posts: 909 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States ![]() ![]() |
Sorry deleted repeat
Attached thumbnail(s) ![]() |
bdstone914 |
Lo-Fi Version | Time is now: 4th April 2025 - 05:24 AM |
