> LN Engineering 2563 Kit
JimVG
post Dec 26 2024, 04:36 PM
Has anyone here built a 914 Type 4 using the LN Engineering 2563-190 kit?
VaccaRabite
post Dec 29 2024, 09:32 AM
En Garde!
IMO - I would not consider the the 2.5 kit engine for several reasons.
1) The 2270 is a well proven engine kit and will outlast the 2563-190 while making about as much power. If you want to build an engine bigger then a 2056, the 2270 is where I would go kit wise. It got the most development from Jake back in the day and there was a LONG time where even he said he preferred it over the 2.5. Look up Jakes beetle the Bluebonic Plague. He drove it across the nation with a 2270, data logged the entire trip, and used that data to make the 2270 an even better engine. IIRC, this car and engine also got air conditioning and a host of other upgrades over the years. I don't know what the kit options are for the 2270 these days, but they used to come in 150ish and 200ish hp versions. If you want a kit engine, I'd look there.
2) 2.5 engines are known for snapping cranks and performing spectacular RUDs (Rapid Unscheduled Disassembly). Too much torque. Too much heat. Too thin components.
3) There are other options if building it yourself is not the goal. I am running a 2.3i (2258) from PMB Performance that makes about 150ish HP. It come ready to install WITH fuel injection. You open the crate and install the engine. No sourcing carbs. No sourcing fuel injection. No tuning (unless you want to). The cost of the "2.3i" from PMB is not that much more expensive then the kit engine. They do require a core engine, and you will wait for several months to a year for your engine to get delivered - but that's likely the same amount of time it would take you to build it yourself. Eric and the crew at PMB are also in constant development for this engine. I got engine #2 from this program. They are in the process of making them even better and taking a mindset of longevity over peak HP. And you get PMB customer service - which is second to none IMO.
Good luck!
Zach
JimVG   LN Engineering 2563 Kit   Dec 26 2024, 04:36 PM
Root_Werks   Hoping someone will chime in. Years back, really w...   Dec 26 2024, 07:06 PM
zig-n-zag   I bought a 2563-190 engine kit from Jake Raby back...   Dec 27 2024, 02:48 AM
JimVG   I bought a 2563-190 engine kit from Jake Raby bac...   Dec 27 2024, 07:33 AM
DC_neun_vierzehn   I bought a 2563-190 engine kit from Jake Raby bac...   Dec 27 2024, 08:51 AM
JOEPROPER   If you go with carbs, I have big Dells that are ne...   Dec 27 2024, 08:57 AM
r_towle   I have a 2.6 Carbs were required at the time I bui...   Dec 27 2024, 09:03 AM
r_towle   No matter what you choose, measure everything to e...   Dec 27 2024, 10:10 AM
JimVG   No matter what you choose, measure everything to ...   Dec 27 2024, 04:59 PM
zig-n-zag   I had Jake do the engine prep which was wrist pin ...   Dec 27 2024, 02:45 PM
JimVG   I had Jake do the engine prep which was wrist pin...   Dec 27 2024, 05:05 PM
technicalninja   I had Jake do the engine prep which was wrist pin...   Dec 27 2024, 02:54 PM
930cabman   How are these large modifications long term? Bett...   Dec 27 2024, 03:16 PM
zig-n-zag   I wonder if you folks remember in the Paddock the ...   Dec 27 2024, 04:35 PM
zig-n-zag   Good friend of mine built a 2.7 6 for his ‘77 91...   Dec 27 2024, 04:57 PM
Chris914n6   Subaru makes a 2.5L that is significantly cheaper,...   Dec 27 2024, 05:24 PM
930cabman   Subaru makes a 2.5L that is significantly cheaper...   Dec 27 2024, 05:28 PM
Superhawk996   [quote name='Chris914n6' post='3183491' date='Dec...   Dec 27 2024, 10:01 PM
zig-n-zag   The camshaft in the engine kit is the 163/86b. Wh...   Dec 27 2024, 05:39 PM
technicalninja   The camshaft in the engine kit is the 163/86b. W...   Dec 27 2024, 06:23 PM
zig-n-zag   In the long term, how long will a Porsche 6 last c...   Dec 27 2024, 06:30 PM
JimVG   In the long term, how long will a Porsche 6 last ...   Dec 28 2024, 08:21 AM
914werke   105 x 74 ? :o Is this dual plug? Thats a helluva...   Dec 27 2024, 07:13 PM
zig-n-zag   The valve lash increased so to find out why I remo...   Dec 27 2024, 07:54 PM
zig-n-zag   I have single plug heads. Going to a dual plug wo...   Dec 27 2024, 08:15 PM
zig-n-zag   The crank is a DPR 78.4mm welded counter weighted....   Dec 27 2024, 08:37 PM
technicalninja   @zig-n-zag Sounds like an ass kicking set up...   Dec 27 2024, 09:06 PM
914werke   The crank is a DPR 78.4mm. The bore is 102mm :...   Dec 28 2024, 12:28 AM
JimVG   I have researched the flat 6 conversion options, a...   Dec 28 2024, 08:24 AM
mepstein   I have researched the flat 6 conversion options, ...   Dec 28 2024, 12:25 PM
JimVG   I have researched the flat 6 conversion options,...   Dec 29 2024, 09:17 AM
930cabman   I have researched the flat 6 conversion options, ...   Dec 29 2024, 03:17 PM
burton73   I don't know what to tell you on this 2562 kit...   Dec 28 2024, 12:30 PM
technicalninja   I have researched the flat 6 conversion options, ...   Dec 28 2024, 01:04 PM
JimVG   I have researched the flat 6 conversion options,...   Dec 30 2024, 12:01 PM
mepstein   The cost of a Porsche six can be hard to justify b...   Dec 28 2024, 03:43 PM
zig-n-zag   The engine kit from Jake was over 11k. The CFR ex...   Dec 28 2024, 09:42 PM
VaccaRabite   IMO - I would not consider the the 2.5 kit engine ...   Dec 29 2024, 09:32 AM
JimVG   IMO - I would not consider the the 2.5 kit engine...   Dec 29 2024, 02:00 PM
gandalf_025   OK, I’ll be the one to say it.. How about a Cor...   Dec 29 2024, 04:42 PM
mepstein   OK, I’ll be the one to say it.. How about a Co...   Dec 29 2024, 06:01 PM
VaccaRabite   OK, I’ll be the one to say it.. How about a C...   Dec 30 2024, 08:15 AM
technicalninja   OK, I’ll be the one to say it.. How about a Co...   Dec 29 2024, 05:08 PM
gandalf_025   Believe it fits.. Kennedy did make an adapter …...   Dec 29 2024, 05:44 PM
Jamie   Believe it fits.. Kennedy did make an adapter â€...   Dec 30 2024, 08:11 AM
JimVG   Thanks to all for your input. I appreciate your ti...   Dec 29 2024, 06:03 PM
930cabman   Thanks to all for your input. I appreciate your t...   Dec 30 2024, 12:46 PM
Superhawk996   Sure, (almost anybody) can stuff almost anything...   Dec 30 2024, 12:53 PM
technicalninja   Believe it fits.. Kennedy did make an adapter â€...   Dec 29 2024, 06:05 PM
zig-n-zag   I checked out my rods and won’t be touching the ...   Dec 29 2024, 07:47 PM
zig-n-zag   A 2270 with a 494 cam and dual 44’s will give a ...   Dec 29 2024, 08:14 PM
914werke   The DTM fan shroud makes it easier when going with...   Dec 29 2024, 10:32 PM
burton73   Just so you guys know: Chevrolet produced around...   Dec 30 2024, 11:49 AM
mepstein   I hardly ever see one on the road.   Dec 30 2024, 11:54 AM
technicalninja   I hardly ever see one on the road. :agree: Bu...   Dec 30 2024, 12:02 PM
technicalninja   It's worth a look at the PMB option... https:...   Dec 30 2024, 01:11 PM
JmuRiz   corvair parked across the street from my house, an...   Dec 30 2024, 02:42 PM
JeffBowlsby   FWIW Clarks Corvairs used to be the go to for the ...   Dec 30 2024, 04:05 PM
Montreal914   What about using a 901 from a 911 and convert it w...   Dec 30 2024, 04:42 PM
technicalninja   the 911 and the T4 rotate clockwise when viewed fr...   Dec 30 2024, 09:40 PM
12 User(s) are reading this topic (12 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 3rd January 2025 - 08:06 PM
