> LN Engineering 2563 Kit
JimVG
post Dec 26 2024, 04:36 PM
Has anyone here built a 914 Type 4 using the LN Engineering 2563-190 kit?
JeffBowlsby
post Dec 30 2024, 04:05 PM
914 Wiring Harnesses
FWIW Clarks Corvairs used to be the go to for the reerse rotation parts
https://ssl.corvair.com/user-cgi/pages.cgi
JimVG   LN Engineering 2563 Kit   Dec 26 2024, 04:36 PM
Root_Werks   Hoping someone will chime in. Years back, really w...   Dec 26 2024, 07:06 PM
zig-n-zag   I bought a 2563-190 engine kit from Jake Raby back...   Dec 27 2024, 02:48 AM
JimVG   I bought a 2563-190 engine kit from Jake Raby bac...   Dec 27 2024, 07:33 AM
DC_neun_vierzehn   I bought a 2563-190 engine kit from Jake Raby bac...   Dec 27 2024, 08:51 AM
JOEPROPER   If you go with carbs, I have big Dells that are ne...   Dec 27 2024, 08:57 AM
r_towle   I have a 2.6 Carbs were required at the time I bui...   Dec 27 2024, 09:03 AM
r_towle   No matter what you choose, measure everything to e...   Dec 27 2024, 10:10 AM
JimVG   No matter what you choose, measure everything to ...   Dec 27 2024, 04:59 PM
zig-n-zag   I had Jake do the engine prep which was wrist pin ...   Dec 27 2024, 02:45 PM
JimVG   I had Jake do the engine prep which was wrist pin...   Dec 27 2024, 05:05 PM
technicalninja   I had Jake do the engine prep which was wrist pin...   Dec 27 2024, 02:54 PM
930cabman   How are these large modifications long term? Bett...   Dec 27 2024, 03:16 PM
zig-n-zag   I wonder if you folks remember in the Paddock the ...   Dec 27 2024, 04:35 PM
zig-n-zag   Good friend of mine built a 2.7 6 for his ‘77 91...   Dec 27 2024, 04:57 PM
Chris914n6   Subaru makes a 2.5L that is significantly cheaper,...   Dec 27 2024, 05:24 PM
930cabman   Subaru makes a 2.5L that is significantly cheaper...   Dec 27 2024, 05:28 PM
Superhawk996   [quote name='Chris914n6' post='3183491' date='Dec...   Dec 27 2024, 10:01 PM
zig-n-zag   The camshaft in the engine kit is the 163/86b. Wh...   Dec 27 2024, 05:39 PM
technicalninja   The camshaft in the engine kit is the 163/86b. W...   Dec 27 2024, 06:23 PM
zig-n-zag   In the long term, how long will a Porsche 6 last c...   Dec 27 2024, 06:30 PM
JimVG   In the long term, how long will a Porsche 6 last ...   Dec 28 2024, 08:21 AM
914werke   105 x 74 ? :o Is this dual plug? Thats a helluva...   Dec 27 2024, 07:13 PM
zig-n-zag   The valve lash increased so to find out why I remo...   Dec 27 2024, 07:54 PM
zig-n-zag   I have single plug heads. Going to a dual plug wo...   Dec 27 2024, 08:15 PM
zig-n-zag   The crank is a DPR 78.4mm welded counter weighted....   Dec 27 2024, 08:37 PM
technicalninja   @zig-n-zag Sounds like an ass kicking set up...   Dec 27 2024, 09:06 PM
914werke   The crank is a DPR 78.4mm. The bore is 102mm :...   Dec 28 2024, 12:28 AM
JimVG   I have researched the flat 6 conversion options, a...   Dec 28 2024, 08:24 AM
mepstein   I have researched the flat 6 conversion options, ...   Dec 28 2024, 12:25 PM
JimVG   I have researched the flat 6 conversion options,...   Dec 29 2024, 09:17 AM
930cabman   I have researched the flat 6 conversion options, ...   Dec 29 2024, 03:17 PM
burton73   I don't know what to tell you on this 2562 kit...   Dec 28 2024, 12:30 PM
technicalninja   I have researched the flat 6 conversion options, ...   Dec 28 2024, 01:04 PM
JimVG   I have researched the flat 6 conversion options,...   Dec 30 2024, 12:01 PM
mepstein   The cost of a Porsche six can be hard to justify b...   Dec 28 2024, 03:43 PM
zig-n-zag   The engine kit from Jake was over 11k. The CFR ex...   Dec 28 2024, 09:42 PM
VaccaRabite   IMO - I would not consider the the 2.5 kit engine ...   Dec 29 2024, 09:32 AM
JimVG   IMO - I would not consider the the 2.5 kit engine...   Dec 29 2024, 02:00 PM
gandalf_025   OK, I’ll be the one to say it.. How about a Cor...   Dec 29 2024, 04:42 PM
mepstein   OK, I’ll be the one to say it.. How about a Co...   Dec 29 2024, 06:01 PM
VaccaRabite   OK, I’ll be the one to say it.. How about a C...   Dec 30 2024, 08:15 AM
technicalninja   OK, I’ll be the one to say it.. How about a Co...   Dec 29 2024, 05:08 PM
gandalf_025   Believe it fits.. Kennedy did make an adapter …...   Dec 29 2024, 05:44 PM
Jamie   Believe it fits.. Kennedy did make an adapter â€...   Dec 30 2024, 08:11 AM
JimVG   Thanks to all for your input. I appreciate your ti...   Dec 29 2024, 06:03 PM
930cabman   Thanks to all for your input. I appreciate your t...   Dec 30 2024, 12:46 PM
Superhawk996   Sure, (almost anybody) can stuff almost anything...   Dec 30 2024, 12:53 PM
technicalninja   Believe it fits.. Kennedy did make an adapter â€...   Dec 29 2024, 06:05 PM
zig-n-zag   I checked out my rods and won’t be touching the ...   Dec 29 2024, 07:47 PM
zig-n-zag   A 2270 with a 494 cam and dual 44’s will give a ...   Dec 29 2024, 08:14 PM
914werke   The DTM fan shroud makes it easier when going with...   Dec 29 2024, 10:32 PM
burton73   Just so you guys know: Chevrolet produced around...   Dec 30 2024, 11:49 AM
mepstein   I hardly ever see one on the road.   Dec 30 2024, 11:54 AM
technicalninja   I hardly ever see one on the road. :agree: Bu...   Dec 30 2024, 12:02 PM
technicalninja   It's worth a look at the PMB option... https:...   Dec 30 2024, 01:11 PM
JmuRiz   corvair parked across the street from my house, an...   Dec 30 2024, 02:42 PM
JeffBowlsby   FWIW Clarks Corvairs used to be the go to for the ...   Dec 30 2024, 04:05 PM
Montreal914   What about using a 901 from a 911 and convert it w...   Dec 30 2024, 04:42 PM
technicalninja   the 911 and the T4 rotate clockwise when viewed fr...   Dec 30 2024, 09:40 PM
- Lo-Fi Version Time is now: 3rd January 2025 - 07:48 PM
