> Fred's 2375 Rebuild Thread
friethmiller
post Dec 31 2024, 12:12 PM
[A softball question for the Ninja and/or others]
This is the cam card that came with my 2357 engine, which was originally built by Rimco/Fat (long block) a few years ago. Can someone explain why with an intake/exhaust of 448, the lift was only set to 327 degrees? I'm about to rebuild my motor and a lot of focus will be directed at piston "deck clearance" and the valve train geometry that wasn't set correctly. Thanks.
technicalninja
post Dec 31 2024, 03:28 PM
WOW!
Was that engine in the car the time you visited?
All of your cam shit is DEAD! I wouldn't trust a bit of it.
That "super deluxe" kit from LN is looking better.
No register milling?
The new "machined" finish is almost worth it alone.
On an MLS gasket it's a requirement...
(IMG:style_emoticons/default/WTF.gif)
Yet another story of ineptitude at the "professional" shop level...
(IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
82 is BIG! I would expect camshaft interference is more critical at this level.
Another reason to choose LN maybe...
You need to learn how to do simple "blue-printing" on the engine.
I can HELP! (IMG:style_emoticons/default/ninja.gif)
friethmiller   Fred's 2375 Rebuild Thread   Dec 31 2024, 12:12 PM
technicalninja   It's probably showing actual lift of the lobe....   Dec 31 2024, 12:31 PM
friethmiller   It's probably showing actual lift of the lobe...   Dec 31 2024, 12:45 PM
technicalninja   looking again that whole cam card is at .050! ...   Dec 31 2024, 12:50 PM
friethmiller   looking again that whole cam card is at .050...   Dec 31 2024, 01:09 PM
technicalninja   I'd have to see the cam card on it. I'd l...   Dec 31 2024, 01:38 PM
technicalninja   Changing cam in a T4 means "all the way down...   Dec 31 2024, 02:13 PM
friethmiller   Ok, I've changed to name of this thread to han...   Dec 31 2024, 02:50 PM
technicalninja   WOW! Was that engine in the car the time you ...   Dec 31 2024, 03:28 PM
technicalninja   Pics please! Clean and label all of the split...   Dec 31 2024, 03:39 PM
friethmiller   Pics please! Clean and label all of the spli...   Dec 31 2024, 04:44 PM
friethmiller   Engine pics Tear down: ...   Dec 31 2024, 05:39 PM
friethmiller   More Pics Camshaft: [u]Camshaft Bearings: ...   Dec 31 2024, 07:06 PM
friethmiller   More Pics: Note: any perpendicular marks are from...   Dec 31 2024, 07:23 PM
friethmiller   Crankshaft Journal Measurements: Note: main jour...   Dec 31 2024, 07:51 PM
technicalninja   Reality check... I never said anything because it...   Jan 1 2025, 10:28 AM
friethmiller   Reality check... I never said anything because i...   Jan 1 2025, 11:06 AM
technicalninja   Are the pistons true flat tops with no valve depre...   Jan 1 2025, 11:08 AM
friethmiller   Are the pistons true flat tops with no valve depr...   Jan 1 2025, 11:19 AM
technicalninja   I MAY have a close machine shop. Replacing everyt...   Jan 1 2025, 11:28 AM
friethmiller   Web Cam has a 494 grind with a 1” base circle me...   Jan 1 2025, 02:08 PM
technicalninja   Those might not be JE pistons! I have 2 new s...   Jan 1 2025, 02:24 PM
technicalninja   Looked at that cam. That wouldn't be my first ...   Jan 1 2025, 02:47 PM
friethmiller   Interesting, I'll take a look here in a bit. ...   Jan 1 2025, 03:25 PM
technicalninja   Flat top 96mm 82 stroke. 593.53 CC swept volume. T...   Jan 1 2025, 03:42 PM
technicalninja   Those ARE Keith Black "silverlines". Tha...   Jan 1 2025, 04:03 PM
friethmiller   Those ARE Keith Black "silverlines". Th...   Jan 1 2025, 05:56 PM
technicalninja   I noticed it almost looks like those have a solid ...   Jan 1 2025, 04:14 PM
Jack Standz   Just some thoughts and first impressions. Thos...   Jan 1 2025, 04:56 PM
friethmiller   Just some thoughts and first impressions. Tho...   Jan 1 2025, 06:08 PM
Jack Standz   Since you're rebuilding the motor, let me sup...   Jan 1 2025, 05:20 PM
friethmiller   9.7:1 Compression Ratio. Damn! That is hot...   Jan 1 2025, 06:20 PM
technicalninja   Intake and exhaust are fine, should support deep i...   Jan 1 2025, 07:25 PM
technicalninja   The pinning is not a big deal. Needs to be done o...   Jan 1 2025, 07:33 PM
friethmiller   Going to cc the heads first. I measured the ID of...   Jan 2 2025, 08:56 AM
technicalninja   The above looks good. Easier to see the bubbles i...   Jan 2 2025, 09:23 AM
technicalninja   These might help. https://www.amazon.com/ABN-Cyli...   Jan 2 2025, 09:26 AM
friethmiller   These might help. https://www.amazon.com/ABN-Cyl...   Jan 2 2025, 09:44 AM
Jack Standz   If/when you get around to ceracoating things, as t...   Jan 2 2025, 09:29 AM
friethmiller   If/when you get around to ceracoating things, as ...   Jan 2 2025, 09:46 AM
technicalninja   If/when you get around to ceracoating things, as...   Jan 2 2025, 09:55 AM
VaccaRabite   I've got some opinions here. Remember that ...   Jan 2 2025, 10:09 AM
friethmiller   I've got some opinions here. ... Zach Z...   Jan 2 2025, 11:21 AM
technicalninja   I've got some opinions here. Remember that...   Jan 2 2025, 01:49 PM
cgnj   Falcor75 2270 made 158 to the wheels with 10:1, 86...   Jan 2 2025, 02:24 PM
friethmiller   Falcor75 2270 made 158 to the wheels with 10:1, 8...   Jan 2 2025, 03:16 PM
friethmiller   Ok, Cylinder test via antifreeze titration says 60...   Jan 2 2025, 03:22 PM
friethmiller   @technicalninja - Initial look at deck height her...   Jan 2 2025, 09:14 PM
friethmiller   BTW. I’ll put the head stud back and tighten it...   Jan 2 2025, 09:57 PM
technicalninja   Normal quench, .040"thick,96mm bore is 7.2 cc...   Jan 2 2025, 10:10 PM
friethmiller   Did FAT supply those pistons? Yes, crank, cam, ...   Jan 2 2025, 10:19 PM
technicalninja   I don't remember what gauges you had... Minim...   Jan 2 2025, 10:32 PM
Jack Standz   VaccaRabite made several good points about the CR....   Jan 3 2025, 12:17 AM
friethmiller   Thanks guys! My head is starting to spin here...   Jan 3 2025, 08:56 AM
technicalninja   I'd go option 1. JE does offer coatings done ...   Jan 3 2025, 09:17 AM
technicalninja   I'd want the cam and its stuff to map out valv...   Jan 3 2025, 09:32 AM
friethmiller   Did you verify total stroke? Need to compare CD...   Jan 3 2025, 09:56 AM
technicalninja   Yep, how far down +/- deck height. Dial caliper w...   Jan 3 2025, 10:14 AM
technicalninja   At this "level" of engine I'd expect...   Jan 3 2025, 10:23 AM
friethmiller   At this "level" of engine I'd expec...   Jan 3 2025, 10:32 AM
friethmiller   Ok :ninja: , I used the two shims under the #1 jug...   Jan 3 2025, 11:02 AM
friethmiller   Ok, my 1.7L rocker arms do NOT have elephant feet....   Jan 3 2025, 11:26 AM
technicalninja   https://aapistons.com/collections/porsche-p...ston...   Jan 3 2025, 11:45 AM
friethmiller   https://aapistons.com/collections/porsche-p...sto...   Jan 3 2025, 12:05 PM
cgnj   @[url=http://www.914world.com/bbs2/index.php?showu...   Jan 3 2025, 12:59 PM
friethmiller   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jan 3 2025, 01:19 PM
densible1   I had EMS http://www.europeanmotorworks.com do the...   Jan 3 2025, 01:31 PM
technicalninja   Check with Eric @ Automotive Machine. https://www...   Jan 3 2025, 02:48 PM
technicalninja   And, if I could, I'd pattern the cam I chose o...   Jan 3 2025, 02:56 PM
friethmiller   Thanks Rick, I'll take my case and crank (+ ...   Jan 3 2025, 03:17 PM
burton73   @ friethmiller I just spent a bit of time with Ma...   Jan 3 2025, 03:30 PM
densible1   @[url=http://www.914world.com/bbs2/index.php?showu...   Jan 3 2025, 04:09 PM
friethmiller   @[url=http://www.914world.com/bbs2/index.php?show...   Jan 4 2025, 07:40 AM
burton73   [quote name='densible1' post='3184740' date='Jan ...   Jan 4 2025, 02:07 PM
Montreal914   I am very far from being an expert but I did a lot...   Jan 3 2025, 04:09 PM
friethmiller   I am very far from being an expert but I did a lo...   Jan 3 2025, 11:11 PM
technicalninja   That RAT engine used those same KBs and a big cam....   Jan 3 2025, 05:58 PM
cgnj   @Montreal914 [b]@[url=http://www.914world.com/bb...   Jan 3 2025, 06:55 PM
friethmiller   I have 3 cases that I'm going to drop off soo...   Jan 4 2025, 05:51 AM
technicalninja   It would be useful to have the shim measurements. ...   Jan 3 2025, 09:10 PM
friethmiller   It would be useful to have the shim measurements....   Jan 3 2025, 10:25 PM
Montreal914   2270 = 78.4 x 96mm 2258 = 78 x 96mm 78.4 cranks w...   Jan 4 2025, 09:16 AM
cgnj   Since we are all spending your money, oil spray gr...   Jan 4 2025, 11:19 AM
friethmiller   Since we are all spending your money, oil spray g...   Jan 6 2025, 01:59 PM
technicalninja   [quote name='technicalninja' post='3184830' date=...   Jan 4 2025, 11:32 AM
technicalninja   I would LOVE to know why the pics don't post o...   Jan 4 2025, 02:55 PM
Superhawk996   100mm   Jan 4 2025, 03:37 PM
technicalninja   At this level of build I would be hunting thermal ...   Jan 4 2025, 03:45 PM
technicalninja   Thanks SH! Look at how thick the walls are. T...   Jan 4 2025, 04:01 PM
technicalninja   Need P-W clearance. If they "sized for forged...   Jan 4 2025, 04:24 PM
friethmiller   Just got back in from welding on the front cross p...   Jan 4 2025, 04:42 PM
technicalninja   and yet another thought... I slipped a set of sto...   Jan 4 2025, 05:05 PM
friethmiller   :ninja: Used a digital micrometer on all piston sk...   Jan 4 2025, 08:18 PM
technicalninja   You need to be halfway down the skirt, below the p...   Jan 4 2025, 08:32 PM
friethmiller   You need to be halfway down the skirt, below the ...   Jan 4 2025, 09:13 PM
technicalninja   That range is GREAT! It almost looks like a ....   Jan 5 2025, 12:04 AM
technicalninja   You have accurate tools. You measured close to ....   Jan 5 2025, 12:25 AM
friethmiller   You have accurate tools. You measured close to ...   Jan 5 2025, 10:20 AM
technicalninja   It's both the sight and the feel in tenths... ...   Jan 5 2025, 01:43 PM
technicalninja   :ninja: Used a digital micrometer on all piston s...   Jan 5 2025, 03:39 PM
57 User(s) are reading this topic (57 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 5th February 2025 - 08:56 AM
