friethmiller |
Senior Member ![]() ![]() ![]() Group: Members Posts: 751 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region ![]() ![]() |
[A softball question for the Ninja and/or others]
This is the cam card that came with my 2357 engine, which was originally built by Rimco/Fat (long block) a few years ago. Can someone explain why with an intake/exhaust of 448, the lift was only set to 327 degrees? I'm about to rebuild my motor and a lot of focus will be directed at piston "deck clearance" and the valve train geometry that wasn't set correctly. Thanks. ![]() |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,377 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
Pics please!
Clean and label all of the split bearings. Crankshaft showing journals. Full bearings interior if possible. Tops of pistons before and after cleaning. sides of pistons/bores. I can look at "old" bearings and see trouble. Sometimes the old bearings are good enough that I reuse them, especially on a recent build. Some of what you have may be usable, but I'd no longer trust anything about the builder... Picks of the carnage please Sir! |
friethmiller |
Pics please! Clean and label all of the split bearings. Crankshaft showing journals. Full bearings interior if possible. Tops of pistons before and after cleaning. sides of pistons/bores. I can look at "old" bearings and see trouble. Sometimes the old bearings are good enough that I reuse them, especially on a recent build. Some of what you have may be usable, but I'd no longer trust anything about the builder... Picks of the carnage please Sir! Yes, this is the car/engine you saw in action this spring. In fact, the engine was running great the entire time - even the day I dropped it from the car. However, it always seemed to run rich and backfired a lot. This leads me to the deck height issue. I forget what you called it [in that other build thread] but, I think it was an issue with this engine. You'll see the build up of carbon on the intake valves and pistons/heads to be too severe for only 6,000 miles. I've spent several days cleaning everything up. I have already mic'd the crank/rod journals. I'll post this info and pics soon! P.S. If anyone thinks this engine issue is upsetting me, you are wrong! I love this sh1t!! (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 5th February 2025 - 09:04 AM |
