| friethmiller |
Dec 31 2024, 12:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,600 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
[A softball question for the Ninja and/or others]
This is the cam card that came with my 2357 engine, which was originally built by Rimco/Fat (long block) a few years ago. Can someone explain why with an intake/exhaust of 448, the lift was only set to 327 degrees? I'm about to rebuild my motor and a lot of focus will be directed at piston "deck clearance" and the valve train geometry that wasn't set correctly. Thanks. ![]() |
| technicalninja |
Jan 1 2025, 02:24 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
Those might not be JE pistons!
I have 2 new sets, Stroker 3.0l L28 Z-car and a 1MM over set for a Miata BP engine. My JEs look different than yours! All the pictures I've found on the internet show ZERO markings on the top. Mine are marked INSIDE the crown on the bottom. Wisecos ARE marked on the top... Everything "forged" I have Wiseco, JE, and Ross has much, much finer machining on the crown. More pics of piston please! Underside, both thrust and non-thrust sides of pistons (the skirts/both sides) and a side view on pin would help. You have a long stroke and short rods: I'm looking for excessive side loading on pistons. (Skirts will be worn) Your bores look OK, not bedded properly but not screwed up. LN does offer JEs flat tops with no valve relief. The pistons in this kit appear to be them. They don't look marked on the top either but it's HARD to see. https://lnengineering.com/type-4-store/engi...orsche-kit.html |
friethmiller Fred's 2375 Rebuild Thread Dec 31 2024, 12:12 PM
technicalninja It's probably showing actual lift of the lobe.... Dec 31 2024, 12:31 PM
friethmiller
It's probably showing actual lift of the lobe... Dec 31 2024, 12:45 PM
technicalninja looking again that whole cam card is at .050!
... Dec 31 2024, 12:50 PM
friethmiller
looking again that whole cam card is at .050... Dec 31 2024, 01:09 PM
technicalninja I'd have to see the cam card on it.
I'd l... Dec 31 2024, 01:38 PM
technicalninja Changing cam in a T4 means "all the way down... Dec 31 2024, 02:13 PM
friethmiller Ok, I've changed to name of this thread to han... Dec 31 2024, 02:50 PM
technicalninja WOW!
Was that engine in the car the time you ... Dec 31 2024, 03:28 PM
technicalninja Pics please!
Clean and label all of the split... Dec 31 2024, 03:39 PM
friethmiller
Pics please!
Clean and label all of the spli... Dec 31 2024, 04:44 PM
friethmiller Engine pics
Tear down:
... Dec 31 2024, 05:39 PM
friethmiller More Pics
Camshaft:
[u]Camshaft Bearings:
... Dec 31 2024, 07:06 PM
friethmiller More Pics:
Note: any perpendicular marks are from... Dec 31 2024, 07:23 PM
friethmiller Crankshaft Journal Measurements:
Note: main jour... Dec 31 2024, 07:51 PM
technicalninja Reality check...
I never said anything because it... Jan 1 2025, 10:28 AM
friethmiller
Reality check...
I never said anything because i... Jan 1 2025, 11:06 AM
technicalninja Are the pistons true flat tops with no valve depre... Jan 1 2025, 11:08 AM
friethmiller
Are the pistons true flat tops with no valve depr... Jan 1 2025, 11:19 AM
technicalninja I MAY have a close machine shop.
Replacing everyt... Jan 1 2025, 11:28 AM
friethmiller Web Cam has a 494 grind with a 1” base circle me... Jan 1 2025, 02:08 PM
technicalninja Looked at that cam. That wouldn't be my first ... Jan 1 2025, 02:47 PM
friethmiller Interesting, I'll take a look here in a bit. ... Jan 1 2025, 03:25 PM
technicalninja Flat top 96mm 82 stroke. 593.53 CC swept volume. T... Jan 1 2025, 03:42 PM
technicalninja Those ARE Keith Black "silverlines".
Tha... Jan 1 2025, 04:03 PM
friethmiller
Th... Jan 1 2025, 05:56 PM
technicalninja I noticed it almost looks like those have a solid ... Jan 1 2025, 04:14 PM
Jack Standz Just some thoughts and first impressions.
Thos... Jan 1 2025, 04:56 PM
friethmiller
Tho... Jan 1 2025, 06:08 PM
Jack Standz Since you're rebuilding the motor, let me sup... Jan 1 2025, 05:20 PM
friethmiller 9.7:1 Compression Ratio. Damn! That is hot... Jan 1 2025, 06:20 PM
technicalninja Intake and exhaust are fine, should support deep i... Jan 1 2025, 07:25 PM
technicalninja The pinning is not a big deal.
Needs to be done o... Jan 1 2025, 07:33 PM
friethmiller Going to cc the heads first. I measured the ID of... Jan 2 2025, 08:56 AM
technicalninja The above looks good.
Easier to see the bubbles i... Jan 2 2025, 09:23 AM
technicalninja These might help.
https://www.amazon.com/ABN-Cyli... Jan 2 2025, 09:26 AM
friethmiller
These might help.
https://www.amazon.com/ABN-Cyl... Jan 2 2025, 09:44 AM
Jack Standz If/when you get around to ceracoating things, as t... Jan 2 2025, 09:29 AM
friethmiller
If/when you get around to ceracoating things, as ... Jan 2 2025, 09:46 AM
technicalninja
If/when you get around to ceracoating things, as... Jan 2 2025, 09:55 AM
VaccaRabite I've got some opinions here.
Remember that ... Jan 2 2025, 10:09 AM
friethmiller
Zach
Z... Jan 2 2025, 11:21 AM
technicalninja
Remember that... Jan 2 2025, 01:49 PM
cgnj Falcor75 2270 made 158 to the wheels with 10:1, 86... Jan 2 2025, 02:24 PM
friethmiller
Falcor75 2270 made 158 to the wheels with 10:1, 8... Jan 2 2025, 03:16 PM
friethmiller Ok, Cylinder test via antifreeze titration says 60... Jan 2 2025, 03:22 PM
friethmiller @technicalninja - Initial look at deck height her... Jan 2 2025, 09:14 PM
friethmiller BTW. I’ll put the head stud back and tighten it... Jan 2 2025, 09:57 PM
technicalninja Normal quench, .040"thick,96mm bore is 7.2 cc... Jan 2 2025, 10:10 PM
friethmiller
Did FAT supply those pistons?
Yes, crank, cam, ... Jan 2 2025, 10:19 PM
technicalninja I don't remember what gauges you had...
Minim... Jan 2 2025, 10:32 PM
Jack Standz VaccaRabite made several good points about the CR.... Jan 3 2025, 12:17 AM
friethmiller Thanks guys! My head is starting to spin here... Jan 3 2025, 08:56 AM
technicalninja I'd go option 1.
JE does offer coatings done ... Jan 3 2025, 09:17 AM
technicalninja I'd want the cam and its stuff to map out valv... Jan 3 2025, 09:32 AM
friethmiller
Did you verify total stroke?
Need to compare CD... Jan 3 2025, 09:56 AM
technicalninja Yep, how far down +/- deck height.
Dial caliper w... Jan 3 2025, 10:14 AM
technicalninja At this "level" of engine I'd expect... Jan 3 2025, 10:23 AM
friethmiller
At this "level" of engine I'd expec... Jan 3 2025, 10:32 AM
friethmiller Ok :ninja: , I used the two shims under the #1 jug... Jan 3 2025, 11:02 AM
friethmiller Ok, my 1.7L rocker arms do NOT have elephant feet.... Jan 3 2025, 11:26 AM
technicalninja https://aapistons.com/collections/porsche-p...ston... Jan 3 2025, 11:45 AM
friethmiller
https://aapistons.com/collections/porsche-p...sto... Jan 3 2025, 12:05 PM
cgnj @[url=http://www.914world.com/bbs2/index.php?showu... Jan 3 2025, 12:59 PM
friethmiller
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jan 3 2025, 01:19 PM
densible1 I had EMS http://www.europeanmotorworks.com do the... Jan 3 2025, 01:31 PM
technicalninja Check with Eric @ Automotive Machine.
https://www... Jan 3 2025, 02:48 PM
technicalninja And, if I could, I'd pattern the cam I chose o... Jan 3 2025, 02:56 PM
friethmiller Thanks Rick,
I'll take my case and crank (+ ... Jan 3 2025, 03:17 PM
burton73 @ friethmiller
I just spent a bit of time with Ma... Jan 3 2025, 03:30 PM
densible1 @[url=http://www.914world.com/bbs2/index.php?showu... Jan 3 2025, 04:09 PM
friethmiller
@[url=http://www.914world.com/bbs2/index.php?show... Jan 4 2025, 07:40 AM
burton73
[quote name='densible1' post='3184740' date='Jan ... Jan 4 2025, 02:07 PM
Montreal914 I am very far from being an expert but I did a lot... Jan 3 2025, 04:09 PM
friethmiller
I am very far from being an expert but I did a lo... Jan 3 2025, 11:11 PM
technicalninja That RAT engine used those same KBs and a big cam.... Jan 3 2025, 05:58 PM
cgnj @Montreal914 [b]@[url=http://www.914world.com/bb... Jan 3 2025, 06:55 PM
friethmiller
I have 3 cases that I'm going to drop off soo... Jan 4 2025, 05:51 AM
technicalninja It would be useful to have the shim measurements.
... Jan 3 2025, 09:10 PM
friethmiller
It would be useful to have the shim measurements.... Jan 3 2025, 10:25 PM
Montreal914 2270 = 78.4 x 96mm
2258 = 78 x 96mm
78.4 cranks w... Jan 4 2025, 09:16 AM
cgnj Since we are all spending your money, oil spray gr... Jan 4 2025, 11:19 AM
friethmiller
Since we are all spending your money, oil spray g... Jan 6 2025, 01:59 PM
technicalninja
[quote name='technicalninja' post='3184830' date=... Jan 4 2025, 11:32 AM
technicalninja I would LOVE to know why the pics don't post o... Jan 4 2025, 02:55 PM
Superhawk996 100mm
Jan 4 2025, 03:37 PM
technicalninja At this level of build I would be hunting thermal ... Jan 4 2025, 03:45 PM
technicalninja Thanks SH!
Look at how thick the walls are. T... Jan 4 2025, 04:01 PM
technicalninja Need P-W clearance. If they "sized for forged... Jan 4 2025, 04:24 PM
friethmiller Just got back in from welding on the front cross p... Jan 4 2025, 04:42 PM
technicalninja and yet another thought...
I slipped a set of sto... Jan 4 2025, 05:05 PM
friethmiller :ninja: Used a digital micrometer on all piston sk... Jan 4 2025, 08:18 PM
technicalninja You need to be halfway down the skirt, below the p... Jan 4 2025, 08:32 PM
friethmiller
You need to be halfway down the skirt, below the ... Jan 4 2025, 09:13 PM
technicalninja That range is GREAT!
It almost looks like a .... Jan 5 2025, 12:04 AM
technicalninja You have accurate tools.
You measured close to .... Jan 5 2025, 12:25 AM
friethmiller
You measured close to ... Jan 5 2025, 10:20 AM
technicalninja It's both the sight and the feel in tenths...
... Jan 5 2025, 01:43 PM
technicalninja
:ninja: Used a digital micrometer on all piston s... Jan 5 2025, 03:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 31st October 2026 - 08:24 PM |
