Fred's 2375 Rebuild Thread |
friethmiller |
Dec 31 2024, 12:12 PM
Senior Member Group: Members Posts: 751 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
[A softball question for the Ninja and/or others]
This is the cam card that came with my 2357 engine, which was originally built by Rimco/Fat (long block) a few years ago. Can someone explain why with an intake/exhaust of 448, the lift was only set to 327 degrees? I'm about to rebuild my motor and a lot of focus will be directed at piston "deck clearance" and the valve train geometry that wasn't set correctly. Thanks. |
friethmiller |
Jan 3 2025, 11:02 AM
Ok (IMG:style_emoticons/default/ninja.gif) , I used the two shims under the #1 jug and traversed a total of 84.52mm down from the top with a measured deck height of 2.5mm. That gives me 82.02mm of stroke. So, 82mm confirmed!
Lo-Fi Version | Time is now: 5th February 2025 - 08:43 AM |
