Fred's 2375 Rebuild Thread |
friethmiller |
Dec 31 2024, 12:12 PM
Senior Member Group: Members Posts: 751 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
[A softball question for the Ninja and/or others]
This is the cam card that came with my 2357 engine, which was originally built by Rimco/Fat (long block) a few years ago. Can someone explain why with an intake/exhaust of 448, the lift was only set to 327 degrees? I'm about to rebuild my motor and a lot of focus will be directed at piston "deck clearance" and the valve train geometry that wasn't set correctly. Thanks. |
technicalninja |
Jan 3 2025, 11:45 AM
Advanced Member Group: Members Posts: 2,377 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
https://aapistons.com/collections/porsche-p...ston-with-biral
There's one. Almost looks like that doesn't intersect the pin bore. Might not work with your crank/rods. Have to do some math... The elephant feet help the rocker with angularity. Allows more usable range. Baby cams don't really need them. You will NOT have a baby cam in that engine. |
Lo-Fi Version | Time is now: 5th February 2025 - 08:40 AM |
