1976 fuel injection questions |
914incali |
Apr 2 2024, 11:07 AM
Newbie Group: Members Posts: 4 Joined: 16-February 24 From: bakersfield Member No.: 27,944 Region Association: None |
Picked up a 76 out of texas that had been converted to single carb that just doesn't run very well. I decided to convert back to original FI, essentially everything is gone and I am working on understanding the system. I guess my first question is where does the fuel pump draw power from? there is a single black wire underneath the fuel tank that has no power to it but all the relays have been removed and Im waiting on those from pelican
JeffBowlsby |
Jan 6 2025, 12:48 PM
914 Wiring Harnesses Group: Members Posts: 8,788 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Post a photo of that oblong hole so we clearly understand? You are describing a significant vacuum leak that would elevate idle. Perhaps you can cover it temporarily on the outer TB surface such as with a small strip of duct tape or metal adhesive tape, then open up the idle screw on the TB to adjust the idle correctly.
Lo-Fi Version | Time is now: 8th January 2025 - 07:29 AM |
