> 1976 fuel injection questions
914incali
post Apr 2 2024, 11:07 AM
Picked up a 76 out of texas that had been converted to single carb that just doesn't run very well. I decided to convert back to original FI, essentially everything is gone and I am working on understanding the system. I guess my first question is where does the fuel pump draw power from? there is a single black wire underneath the fuel tank that has no power to it but all the relays have been removed and Im waiting on those from pelican
rjames
post Jan 7 2025, 11:05 AM
I'm made of metal
My butterfly plate has a hole in it with a screw and nut that looks original because the bottom threads of the screw are peened to prevent removal . I'm not really sure about that as Ive seen some with and with out holes but never the screw in the hole .
The butterfly should have two screws that hold the throttle body to the lever. Most TBs have an additional hole to allow some air in. There are some butterflies that don't have the additional hole. It sounds like someone blocked the hole on yours using a screw and a nut to compensate for a high idle (vacuum leak).
914incali   1976 fuel injection questions   Apr 2 2024, 11:07 AM
dr914@autoatlanta.com   power is from the relay board in the engine compar...   Apr 2 2024, 11:18 AM
914incali   I have a complete injection system and am waiting ...   Apr 2 2024, 11:34 AM
rjames   Black and red= power, brown=ground to chassis.   Apr 2 2024, 11:54 AM
914incali   Black and red= power, brown=ground to chassis. ...   Apr 2 2024, 12:12 PM
JeffBowlsby   Single brown ground cable for the fuel pump is se...   Apr 2 2024, 01:15 PM
914incali   yes its out of a 73 2.0, im not to worried about s...   Apr 2 2024, 01:31 PM
fiacra   yes its out of a 73 2.0, im not to worried about ...   Apr 2 2024, 10:02 PM
L-Jet914   yes its out of a 73 2.0, im not to worried about ...   Oct 10 2024, 11:33 PM
burton73   The problem is you are in California, and you need...   Apr 2 2024, 01:39 PM
Karl R   Also that is the wrong FI for your car. Your 1976...   Apr 3 2024, 07:04 PM
JeffBowlsby   Also that is the wrong FI for your car. Your 197...   Apr 3 2024, 07:23 PM
wonkipop   Also that is the wrong FI for your car. Your 19...   Apr 4 2024, 06:10 PM
Ron914   [quote name='JeffBowlsby' post='3137731' date='Ap...   Oct 9 2024, 12:42 PM
wonkipop   [quote name='JeffBowlsby' post='3137731' date='A...   Oct 9 2024, 04:15 PM
L-Jet914   [quote name='JeffBowlsby' post='3137731' date='A...   Oct 10 2024, 11:17 PM
r_towle   76 is djet. I happen to have one here if you need...   Apr 3 2024, 08:23 PM
Karl R   I guess I'm starting to slip. I thought they s...   Apr 4 2024, 04:39 PM
r_towle   I guess I'm starting to slip. I thought they ...   Apr 4 2024, 05:31 PM
JeffBowlsby   For smog purposes CA-only model 1975-76 914s also ...   Oct 9 2024, 05:15 PM
wonkipop   @Ron914 here is what CARB would have on file for...   Oct 9 2024, 08:06 PM
Ron914   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Oct 10 2024, 04:58 PM
wonkipop   well i can only speak as an australian down here...   Oct 10 2024, 06:57 PM
fiacra   [quote name='wonkipop' post='3172034' date='Oct 9...   Oct 10 2024, 11:14 PM
Ron914   [quote name='wonkipop' post='3172034' date='Oct ...   Oct 10 2024, 11:47 PM
L-Jet914   [quote name='fiacra' post='3172200' date='Oct 11 ...   Oct 10 2024, 11:57 PM
wonkipop   [quote name='fiacra' post='3172200' date='Oct 11 ...   Oct 11 2024, 12:41 AM
JeffBowlsby   Did paperwork from the previous smog tests come wi...   Oct 10 2024, 05:28 PM
wonkipop   on the question of how the previous owner got the ...   Oct 10 2024, 07:07 PM
wonkipop   @JeffBowlsby you always throw up interesting inf...   Oct 10 2024, 07:22 PM
JeffBowlsby   Yes! It’s in the Service &Training manu...   Oct 10 2024, 07:48 PM
JeffBowlsby   I have at least one 75 CA 2.0L with the SL box on ...   Oct 10 2024, 07:58 PM
wonkipop   I have at least one 75 CA 2.0L with the SL box on...   Oct 10 2024, 09:44 PM
JeffBowlsby   [quote name='JeffBowlsby' post='3172179' date='Oc...   Oct 10 2024, 10:15 PM
wonkipop   [quote name='JeffBowlsby' post='3172179' date='O...   Oct 11 2024, 12:38 AM
Ron914   When I bought the car I had to go to the DMV and p...   Oct 10 2024, 10:47 PM
L-Jet914   If you have a plate number you can see the pass/fa...   Oct 10 2024, 11:03 PM
L-Jet914   Everything required for a California certified 197...   Oct 10 2024, 11:28 PM
wonkipop   Everything required for a California certified 19...   Oct 11 2024, 12:39 AM
930cabman   Glad I don't live in Cali   Oct 11 2024, 05:04 AM
fiacra   Glad I don't live in Cali It ain't bad ...   Oct 11 2024, 03:29 PM
emerygt350   Absolutely agree. Drives me crazy living in NY tr...   Oct 11 2024, 06:35 PM
davep   So Ron, what is the current situation?   Jan 5 2025, 03:30 PM
fiacra   @914incali [b]@[url=http://www.914world.com/bbs2...   Jan 5 2025, 03:57 PM
Ron914   Thanks for checking in . I am still working on my ...   Jan 6 2025, 12:28 PM
Ron914   I believe it was @ emerygt350 that asked @slapsho...   Jan 6 2025, 12:35 PM
JeffBowlsby   Post a photo of that oblong hole so we clearly und...   Jan 6 2025, 12:48 PM
rjames   Post a photo of that oblong hole so we clearly un...   Jan 6 2025, 02:02 PM
emerygt350   If the idle adjust screw no longer closes off the ...   Jan 6 2025, 02:54 PM
Ron914   I would really like to post a photo or video but l...   Jan 6 2025, 04:44 PM
burton73   I would really like to post a photo or video but ...   Jan 6 2025, 06:19 PM
Ron914   [quote name='Ron914' post='3185256' date='Jan 6 2...   Jan 6 2025, 06:37 PM
burton73   Sending this to Rick as well. You are very close...   Jan 6 2025, 09:28 PM
emerygt350   You are all good with that butterfly. That is how...   Jan 6 2025, 06:08 PM
Ron914   You are all good with that butterfly. That is ho...   Jan 6 2025, 07:04 PM
technicalninja   Thanks Bob!   Jan 7 2025, 09:20 AM
rjames   The butterfly should have two screws that hold t...   Jan 7 2025, 11:05 AM
emerygt350   The butterfly should have two screws that hold ...   Jan 7 2025, 12:47 PM
Ron914   The butterfly should have two screws that hold...   Jan 7 2025, 02:34 PM
emerygt350   At the current state I would leave it in the hole,...   Jan 7 2025, 07:56 PM
- Lo-Fi Version Time is now: 9th January 2025 - 12:22 AM
