> Rear trailing arm broken bolts, How in trouble am I??
PaIsa
post Jan 7 2025, 06:19 PM
Long story short, 2 of the 3 bolts holding the left rear trailing arm broke on me. One broke and left some of the bolt out of the hole so I thought I could get it with heat and vise grip but nope. She is stuck. The other one broke and what is left is in the hole.
I cannot believe I am the first 914 owner dealing with this.
As I said, for the bolt that left me something to work with my plan was to heat it and use vise grip to try to get it. Tried on multiple occasion but she does not want to come out.
For the other one I guess I only have left to dril it out and try to redo the threads hoping for the best.
Does anyone has any other advice or method to try.
I do not have a welding machine so welding a nut is not an option for now and not sure it would work (for the one that sticks out of the hole).
I am open for any advice. I plan to work on this with my son this weekend.
Thanks
Superhawk996
post Jan 7 2025, 07:46 PM
You are so (IMG:style_emoticons/default/sheeplove.gif) especially on those that broke off inside the bobbin. I don’t envy you. May God give you lots of courage and patience.
Ninja’s suggestions are solid. Start soaking the fasteners today!
Personally I’d consider hiring someone with a welder to deal with the exposed one.
On the ones broken off under flush - I’d find or fabricate a drill guide to keep any drilling with left hand drill bits centered. I would also pre-grind the underflush fastener as flat as I could get it to prevent the drill tip from waking off center on a jagged - fractured bolt.
Regardless of what happens . . . For the love of God, don’t try to use a bolt extractor
I had one of these come to me pre-broken and with a broken off EZ out in the bolt when I bought my car. I ended up replacing the bobbin during a compete restoration surgery. Details in my build thread if you want a view to the internals of what you’re dealing with. Page 3, post #46. Link to my build in my signature.
I dread thinking about doing this on car & upside down. The saving grace is that Tangerine Racing sells the bobbins if it all goes to (IMG:style_emoticons/default/stromberg.gif) They are weld in and a whole project unto itself . . . But at least they are available vs having to fabricate them from scratch.
Give it your best and if you need clarification on how to make the drill guide, etc. just ask for more clarification.
JamesM
post Jan 7 2025, 08:29 PM
QUOTE(Superhawk996 @ Jan 7 2025, 06:46 PM) *
Quit scaring him, its not that bad! (IMG:style_emoticons/default/tongue.gif)
Annoying yes, end of the world, no. Im sure he has much bigger issues with his car, he just doesn't know about them yet.
Pretty much what everyone else said though, soak the crap out of it, get a stud extraction kit and attempt to drill/extract. This can potentially be done from above or below.
Worst case you totally destroy the threads the cylindrical threaded sleeve is just held in with a few welds and can be replaced. Tangerine used to sell these new, not sure if they still do. Even if you destroy just some of the threads its fully threaded longer than the bolt so you can get a slightly longer bolt to grab more threads.
Once you get the bolts out though chase all the threads with a tap and get new bolts, those all look pretty hammered.
PaIsa   Rear trailing arm broken bolts   Jan 7 2025, 06:19 PM
technicalninja   Those bolts go all the way through the body and ha...   Jan 7 2025, 06:39 PM
technicalninja   It's possible to catch the undercoat on fire, ...   Jan 7 2025, 07:00 PM
Superhawk996   You are so :miles: especially on those that broke...   Jan 7 2025, 07:46 PM
JamesM   You are so :miles: especially on those that brok...   Jan 7 2025, 08:29 PM
Superhawk996   You are so :miles: especially on those that bro...   Jan 7 2025, 08:37 PM
mgp4591   You are so :miles: especially on those that bro...   Mar 5 2025, 11:13 PM
r_towle   I remember @chris foley [b]@[url=http://www.914...   Jan 7 2025, 08:28 PM
PaIsa   One thing that I am unsure of is the fact that the...   Jan 8 2025, 06:02 AM
930cabman   sorry, this is not an easy fix and has been mentio...   Jan 8 2025, 11:54 AM
ChrisFoley   I successfully drilled out 3 of 6 on a car in my s...   Jan 8 2025, 12:28 PM
Superhawk996   I used to sell replacement sleeves. What do you ...   Jan 8 2025, 12:39 PM
ChrisFoley   What do you mean - used to? :shock1: The sm...   Jan 8 2025, 01:59 PM
914werke   One thing that I am unsure of is the fact that th...   Jan 8 2025, 12:33 PM
PaIsa   One thing that I am unsure of is the fact that t...   Jan 8 2025, 12:51 PM
Superhawk996   Mine seem to be capped like 1/2 to 3/4'...   Jan 8 2025, 01:37 PM
ChrisFoley   [quote name='914werke' post='3185572' date='Jan 8...   Jan 8 2025, 02:12 PM
technicalninja   I've got a 31K mile 75 that definitely had the...   Jan 8 2025, 12:41 PM
rudedude   All three are open from above with the plastic cap...   Jan 8 2025, 12:43 PM
Ishley   You might consider just getting the threaded bobbi...   Jan 8 2025, 01:47 PM
PaIsa   So my son and I were able to deal with the buried ...   Jan 10 2025, 06:46 PM
Spoke   I had the same thing happen to every one of my stu...   Jan 10 2025, 07:43 PM
rhodyguy   Aerokroil is a first rate penetrant. Spray generou...   Jan 10 2025, 08:06 PM
Superhawk996   Drill bits, taps and thread chasers get expensive...   Jan 10 2025, 08:08 PM
technicalninja   My left-handed cobalt's are my most prized dri...   Jan 10 2025, 08:14 PM
PaIsa   So following up on this. Last week end, with the ...   Mar 5 2025, 04:16 PM
Superhawk996   One question I would have is to know if someone ...   Mar 5 2025, 11:22 PM
Ishley   Check this post for some pictures. http://www.91...   Mar 5 2025, 08:34 PM
peteyd   We also have these available for left and right. I...   Mar 7 2025, 08:02 AM
930cabman   We also have these available for left and right. ...   Mar 7 2025, 04:11 PM
PaIsa   Replacement bobbins already delivered. Will work ...   Mar 10 2025, 10:37 AM
Ishley   You might consider making some sort of a jig to re...   Mar 11 2025, 09:15 PM
- Lo-Fi Version Time is now: 12th March 2025 - 01:06 PM
