> Rear trailing arm broken bolts, How in trouble am I??
PaIsa
post Jan 7 2025, 06:19 PM
Long story short, 2 of the 3 bolts holding the left rear trailing arm broke on me. One broke and left some of the bolt out of the hole so I thought I could get it with heat and vise grip but nope. She is stuck. The other one broke and what is left is in the hole.
I cannot believe I am the first 914 owner dealing with this.
As I said, for the bolt that left me something to work with my plan was to heat it and use vise grip to try to get it. Tried on multiple occasion but she does not want to come out.
For the other one I guess I only have left to dril it out and try to redo the threads hoping for the best.
Does anyone has any other advice or method to try.
I do not have a welding machine so welding a nut is not an option for now and not sure it would work (for the one that sticks out of the hole).
I am open for any advice. I plan to work on this with my son this weekend.
Thanks
ChrisFoley
post Jan 8 2025, 12:28 PM
I am Tangerine Racing
I successfully drilled out 3 of 6 on a car in my shop, just last month.
It is one of the worst repair jobs on a 914.
Saving the threads is important because the next level of repair involves replacing the heavy steel sleeve that the bolts thread into.
I used to sell replacement sleeves.
Superhawk996
post Jan 8 2025, 12:39 PM
QUOTE(ChrisFoley @ Jan 8 2025, 02:28 PM) *
What do you mean - used to? (IMG:style_emoticons/default/new_shocked.gif)
Those bobbins were lifesavers vs having to machine from scratch. But ya I get it - probably don’t move many per year and not a money maker
Oh man, being able to buy one from you was a real timesaver for me back around 2018 or so!
ChrisFoley
post Jan 8 2025, 01:59 PM
QUOTE(Superhawk996 @ Jan 8 2025, 01:39 PM) *
The small quantity I have remaining is reserved in case anyone buys one of my raised suspension kits. (IMG:style_emoticons/default/smile.gif)
PaIsa   Rear trailing arm broken bolts   Jan 7 2025, 06:19 PM
technicalninja   Those bolts go all the way through the body and ha...   Jan 7 2025, 06:39 PM
technicalninja   It's possible to catch the undercoat on fire, ...   Jan 7 2025, 07:00 PM
Superhawk996   You are so :miles: especially on those that broke...   Jan 7 2025, 07:46 PM
JamesM   You are so :miles: especially on those that brok...   Jan 7 2025, 08:29 PM
Superhawk996   You are so :miles: especially on those that bro...   Jan 7 2025, 08:37 PM
mgp4591   You are so :miles: especially on those that bro...   Mar 5 2025, 11:13 PM
r_towle   I remember @chris foley [b]@[url=http://www.914...   Jan 7 2025, 08:28 PM
PaIsa   One thing that I am unsure of is the fact that the...   Jan 8 2025, 06:02 AM
930cabman   sorry, this is not an easy fix and has been mentio...   Jan 8 2025, 11:54 AM
ChrisFoley   I successfully drilled out 3 of 6 on a car in my s...   Jan 8 2025, 12:28 PM
Superhawk996   I used to sell replacement sleeves. What do you ...   Jan 8 2025, 12:39 PM
ChrisFoley   What do you mean - used to? :shock1: The sm...   Jan 8 2025, 01:59 PM
914werke   One thing that I am unsure of is the fact that th...   Jan 8 2025, 12:33 PM
PaIsa   One thing that I am unsure of is the fact that t...   Jan 8 2025, 12:51 PM
Superhawk996   Mine seem to be capped like 1/2 to 3/4'...   Jan 8 2025, 01:37 PM
ChrisFoley   [quote name='914werke' post='3185572' date='Jan 8...   Jan 8 2025, 02:12 PM
technicalninja   I've got a 31K mile 75 that definitely had the...   Jan 8 2025, 12:41 PM
rudedude   All three are open from above with the plastic cap...   Jan 8 2025, 12:43 PM
Ishley   You might consider just getting the threaded bobbi...   Jan 8 2025, 01:47 PM
PaIsa   So my son and I were able to deal with the buried ...   Jan 10 2025, 06:46 PM
Spoke   I had the same thing happen to every one of my stu...   Jan 10 2025, 07:43 PM
rhodyguy   Aerokroil is a first rate penetrant. Spray generou...   Jan 10 2025, 08:06 PM
Superhawk996   Drill bits, taps and thread chasers get expensive...   Jan 10 2025, 08:08 PM
technicalninja   My left-handed cobalt's are my most prized dri...   Jan 10 2025, 08:14 PM
PaIsa   So following up on this. Last week end, with the ...   Mar 5 2025, 04:16 PM
Superhawk996   One question I would have is to know if someone ...   Mar 5 2025, 11:22 PM
Ishley   Check this post for some pictures. http://www.91...   Mar 5 2025, 08:34 PM
peteyd   We also have these available for left and right. I...   Mar 7 2025, 08:02 AM
930cabman   We also have these available for left and right. ...   Mar 7 2025, 04:11 PM
PaIsa   Replacement bobbins already delivered. Will work ...   Mar 10 2025, 10:37 AM
Ishley   You might consider making some sort of a jig to re...   Mar 11 2025, 09:15 PM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 12th March 2025 - 01:19 PM
