> 914 Front Turn Signal Assembly European conversion kit, Auto Atlanta part number 9146438
Jezibel
post Jan 7 2025, 08:14 PM
Das Echte POORSCHE Fahrer
OK, guys. Here we go again. I just bought the AUTO ATLANTA 'Euro Turn Signal conversion assembly', which is a set of two bulb holders made from stock aluminum sheeting and bent to (supposedly) conform to the lower section of the US type turn signal assembly housing. After quite a bit of trying to make them fit, I finally gave up and am turning to the forum (once again) to find out exactly what's going with this supposedly "...easy conversion set that has satisfied thousands of Auto Atlanta purchasers"...?
It's pretty clear that however they are supposed to 'easily fit' the turn signal housings, they absolutely do not. Any help with this annoying matter would be most appreciated. Frankly, I'm starting to get a teensy bit irritated with some of the items I've gotten from AUTO ATLANTA (including a pricey replica 914GT double grill engine cover that was rather hastily and sloppily put together), recently.
Nuff sed, but any insights on this would be helpful...
Spoke
post Jan 8 2025, 08:42 PM
Jerry
You could always go LED and just drop these boards in. No cutting, no crimping.
Jezibel   914 Front Turn Signal Assembly European conversion kit   Jan 7 2025, 08:14 PM
dr914@autoatlanta.com   patrik hess in germany makes them and he does a go...   Jan 8 2025, 02:30 PM
Jezibel   patrik hess in germany makes them and he does a g...   Jan 8 2025, 04:08 PM
yellowporky   Those euro turn signal kits have been available fo...   Jan 8 2025, 03:16 PM
Jezibel   Those euro turn signal kits have been available f...   Jan 8 2025, 04:15 PM
Spoke   You could always go LED and just drop these boards...   Jan 8 2025, 08:42 PM
mepstein   You could always go LED and just drop these board...   Jan 9 2025, 09:30 AM
rgolia   You could always go LED and just drop these boar...   Jan 10 2025, 08:04 AM
Jezibel   You could always go LED and just drop these board...   Jan 9 2025, 12:59 PM
mepstein   If you have any questions about installing, Jerry/...   Jan 9 2025, 01:18 PM
Cairo94507   I have Jerry's (Spoke) LED's in all of my ...   Jan 9 2025, 01:22 PM
peteyd   I was tinkering with this project a month or two b...   Jan 9 2025, 01:26 PM
eric9144   I have Jerry's (Spoke) LED's in all of my...   Jan 9 2025, 02:18 PM
porschetub   OK, guys. Here we go again. I just bought the AUT...   Jan 9 2025, 03:03 PM
mb911   Martin (last name I don’t recall) use to make an...   Jan 9 2025, 04:27 PM
tygaboy   Martin (last name I don’t recall) use to make a...   Jan 9 2025, 04:54 PM
burton73   Just as a point of reference these are pictures ar...   Jan 9 2025, 04:50 PM
Spoke   Just as a point of reference these are pictures a...   Jan 12 2025, 03:54 PM
ClayPerrine   Clay, would you want to try out these LEDs? I th...   Jan 13 2025, 06:19 AM
Jezibel   WIZARD stuff, Jerry! I am in awe of your multi...   Jan 13 2025, 09:16 AM
SKL1   What spoke said- have them on both cars and it...   Jan 9 2025, 05:57 PM
Spoke   OK, guys. Here we go again. I just bought the AUT...   Jan 9 2025, 08:13 PM
mb911   Sounds like I need to get some cores and start off...   Jan 10 2025, 05:20 AM
Geezer914   Made my own out of polished aluminum sheet.   Jan 10 2025, 06:47 AM
17 User(s) are reading this topic (17 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 5th February 2025 - 12:55 AM
