> Shifter Lever Differences, Tail Shift Levers
jrrobertson
post Jan 11 2025, 08:36 PM
I was putting together a shifter assembly from parts when I noticed that the two shifter levers I had were different lengths at the ball end. Now I am confused as to which one I should use and am hoping someone can help me. Has anyone seen this before? The car I am making the shifter assembly for is a 1971 six. Does the six have a different shift lever than the four?
zoomCat
post Jan 12 2025, 09:26 AM
The shifter levers for a four and a six are the same. What you are likely seeing is short shifter, which is the longer of the two. For tail shifters the short shifter should be used with a spacer to lift it.
Here’s what the original kit looks like, the spacer is on the right.
- Lo-Fi Version Time is now: 12th January 2025 - 04:12 PM
