914 tachometer indicator lights?, Why are there two different 914 tach displays (turn indicator lights)? |
Jezibel |
Jan 10 2025, 05:54 PM
Das Echte POORSCHE Fahrer Group: Members Posts: 47 Joined: 21-January 24 From: Northern California Member No.: 27,868 Region Association: Northern California |
OK, would some wise soul (George/Dr. 914?) please explain to me why there are apparently two different VDO tachs found in 914s...one of which has separate green arrows for left and right turn indicator actuation and the other with a single left side light for both turn indicators and a right-side light indicator that high beam is on?
I refer, of course, to the two small indicator bulbs that sit at the top of the tach face on top-left and top-right? Most cars have separate L/R turn indicator lights, but apparently the Porsche 914 was equipped with both types of tachs? I vaguely recall that the early 914s had the two green arrow indicators type, and later models used the left turn indicator and right high-beam on-indicator type. Thanks in advance. (IMG:style_emoticons/default/confused24.gif) |
Jezibel |
Jan 11 2025, 02:29 PM
Thanks for that clarification, Tony & Jerry. That seems to mirror something along those lines I read elsewhere. Since having a separate L & R indicator light is, in my opinion, quite helpful (nothing irritates me more than carefree people riding along on the freeway with their turn indicators winking merrily away!), perhaps I could acquire one of the earlier year tach instruments and install it in place of my OEM '74 unit. Hopefully no wiring changes would be required. As far as the indicator needle goes, I much prefer the all black version (later type) to the central silver hub type.
Spoke |
Jan 12 2025, 09:47 AM
Jerry Group: Members Posts: 7,116 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Thanks for that clarification, Tony & Jerry. That seems to mirror something along those lines I read elsewhere. Since having a separate L & R indicator light is, in my opinion, quite helpful (nothing irritates me more than carefree people riding along on the freeway with their turn indicators winking merrily away!), perhaps I could acquire one of the earlier year tach instruments and install it in place of my OEM '74 unit. Hopefully no wiring changes would be required. As far as the indicator needle goes, I much prefer the all black version (later type) to the central silver hub type. @Jezibel I did that exact same swap on my '74 914. I swapped the tach case but kept the '74 tach mechanism. You need to have an extra bulb socket, make a small pigtail and run the L and R indicator wires to the hazard switch where all the turnsignal wires end up. Ground the indicators on the tach. Here's a link with pictures to show how I did the swap. Swapping '74 Tach for '72 Tach |
Jezibel |
Jan 12 2025, 01:21 PM
[/quote] I did that exact same swap on my '74 914. I swapped the tach case but kept the '74 tach mechanism.
You need to have an extra bulb socket, make a small pigtail and run the L and R indicator wires to the hazard switch where all the turnsignal wires end up. Ground the indicators on the tach. Here's a link with pictures to show how I did the swap. [/quote] Wow! Thanks for that detailed and illustrated Tach conversion protocol, Jerry! That's pretty impressive to someone like me who has trouble differentiating (+) from (-), electrically speaking. I may try to follow suit but your instructions are pretty clear and the illustrating photographs are perfect, also. I continue to be amazed by the automotive resto-skills of people such as yourself and others on the forum! Clearly, a major part of my knowledge base in automotive repairs and maintenance is deficit. (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/pray.gif) Thank you! |
Lo-Fi Version | Time is now: 12th January 2025 - 07:25 PM |
