FAT Performance 2375cc Type 4 Upright engine $16500 Richmond VA |
SPRBXR |
Jan 13 2025, 10:29 AM
Newbie Group: Members Posts: 6 Joined: 30-December 11 From: RVA Member No.: 13,947 Region Association: None |
Fat Performance Type 4 Engine converted to upright configuation
One of the last engines built by Ron Fleming before he retired and sold Fat Performance to Rimco. 82 counterweighted crank 96 JE Forged Pistons 5.325 forged rods 2 liter 914 heads ported/polished/flowed Dynoed at 200hp/200tq with a mild torquey cam (.465 Lift/280 Duration) 44 IDF Carbs 44/38 SS Valves Windage Tray Porsche Fan Conversion $16500 Located in Richmond, VA Attached thumbnail(s) |
nditiz1 |
Jan 13 2025, 04:03 PM
Senior Member Group: Members Posts: 1,203 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Pretty sure the engine will fit as is.
Things to note into a 914 are the different wiring of course since the alternator is in a different place and has a 911 style setup (just make a connection harness). Even better if it is internally regulated (late style alt). Cooling tin surround will need to fabricated to keep the air above the heads cool. The oil fill will probably not be a problem and the dip stick might be inside the fill tube idk. Maybe a bracket for the throttle cable to hook in. Very cool setup/design. I sold one last year that needed to be rebuilt. 200HP will make a 914 scream. GLWS! |
Lo-Fi Version | Time is now: 5th February 2025 - 01:06 PM |
