> Flasher Relays, How to bench test. ?
jim_hoyland
post Jan 14 2025, 02:43 PM
Get that VIN ?
I have a couple of Hella TBD 26 flasher relays that I would like to test out on the bench.
The pin outs are:
31
49a
49
C
@Spoke
Spoke
post Jan 15 2025, 01:26 PM
Jerry
@jim_hoyland
Here's a schematic showing how to connect the flasher relay to test it.
Pin 49: Connect to 12V power supply
Pin 31: Connect to Ground
Pin 49a: Connect minimum of two 1156 bulbs or equivalent resistor 6 ohm, 50W. Connect the other side of the bulbs/resistor to Ground. The 6 ohm, 50W resistor is one of those ballast resistors sold when one does an LED conversion. Also found at Digikey.
Pin K/C2/C: This pin will be pulled to 12V when the load (bulbs, resistor) is applied. Connect a small bulb to this pin to Ground.
jim_hoyland   Flasher Relays   Jan 14 2025, 02:43 PM
fixer34   Is there a diagram on one side?   Jan 14 2025, 08:25 PM
jim_hoyland   No diagram   Jan 15 2025, 07:46 AM
Spoke   @jim_hoyland Here's a schematic showing how ...   Jan 15 2025, 01:26 PM
- Lo-Fi Version Time is now: 5th February 2025 - 06:50 AM
