> crank no start perplexed, what else
Wew
post Jan 13 2025, 05:11 PM
Hi all,
I have read and done a bunch of research and still no luck getting my ride to turn over.
1973 2.0 with fuel injection. Has a 2056 build with a performance cam. (still within parameters for a fuel injected car)
Battery at 12.6 Volts
Throttle body serviced
Compression: 130 all four cylinders
Spark: yes
Timing: checked and set at 0 TDC. (will set @ 27BTDC at 3500rpm when I can get it to run)
123 ignition rotor pointing at #1 spark plug wire.
Fuel pressure 28 PSI
Checked injectors and they are squirting fuel.
I do not have the proper CHT which I believe should measure at 1300 ohms.
The one I have measures at 2700 ohms.
I had checked the MPS and if memory serves me right it held air for quite a long time at 17 or 20 psi???? I could be wrong on this as this has been a while.
Have checked for vacuum leaks and done a smoke test when car was running and no leaks found.
All new vacuum lines with clamps.
The car would drive fire right up cold and idle rough. It would buck under load and also didn't start if it was warm.
What changed?
I took out the Throttle body and saw fuel in the plenum which I believe is fuel from the cold start injector.
In all my infinite wisdom I ended up messing around with the throttle position sensor and thought I got it back to its correct setting using one of those line testers like Gary Cotton has used in his video. Maybe I am screwing this up but I don't think so..
I also realized that I had the 123ignition vacuum port connected to my retard side (rear) on the throttle body. (advance was plugged). I changed this and put the smaller vacuum line on the 123 ignition and attached to the advanced port on (front) of the throttle body.
Now I get no love... It just cranks and cranks but will not start. (IMG:style_emoticons/default/chair.gif)
I am aware that this is the incorrect CHT. It doesn't seem like these are available in the 1973 version any longer. Any solutions or mods I will gladly take on. Was wondering about one of those potentiometer to draw down the ohms from 2700 to 1300 if that is possible. If so, any specific recommendations on what you used and worked would be appreciated.
Maybe I beat up the TPS. I had purchased it new from 914 rubber and has gotten very little use other than me messing around with it and the short stops and starts trying to get it going. I have attached a couple of pictures.
I don't want to just start throwing parts at this.. It has to be something I did.
Where I am at is I can't even try and make it run better now because it won't even start.
Ugh (IMG:style_emoticons/default/headbang.gif)
I have also included a link to a youtube video I shot prior to changing the vacuum hose from retard to advance. You will see it idles o.k and then when I accelerate it gets sticky and remains at a higher idle. I have checked the throttle cable and it is not wrapped around the clutch cable.
If I had my druthers I would go back to what it was, but again it would flatten out or buck when I would accelerate and hard start once warm.
I lack the intuitive mechanical skills that many other have on this site and am hopeful I can get some advice on next steps.
Much appreciated.
Gary
https://youtube.com/shorts/idT2vM8uaOg?si=MixjnXL2zrQaNrnV
914sgofast2
post Jan 15 2025, 12:53 PM
The "Car Wizard" channel on You Tube recently posted a very appropriate video about the problem you are facing about an Audi that would crank but not start. Since you say your 914 cranks but won't start, your situation is similar. First, take out the air filter and then spray some starting fluid into the car's intake. Crank the car over and see if it starts. It it starts and runs for a few seconds, then the problem is in your fuel system. If it doesn't fire up at all, then your problem is in the ignition system.
Wew
post Jan 15 2025, 01:34 PM
QUOTE(914sgofast2 @ Jan 15 2025, 10:53 AM) *
I will check out the video!
Thank you
Wew   crank no start perplexed   Jan 13 2025, 05:11 PM
Superhawk996   Recheck the basics Confirm spark at all spark pl...   Jan 14 2025, 07:13 AM
rjames   The car should start and run with the TPS disconne...   Jan 14 2025, 09:41 AM
Ruff914   Test for spark on all cylinders and spark timing. ...   Jan 14 2025, 10:37 AM
mb911   Basics should also include key switch function cra...   Jan 14 2025, 10:38 AM
Wew   Thank you very much for all of your input. Will a...   Jan 14 2025, 11:53 AM
emerygt350   All of the above. Your car can start and run with...   Jan 14 2025, 03:27 PM
Lockwodo   I'm wondering if the timing is way off. It wa...   Jan 14 2025, 05:12 PM
ClayPerrine   I am going to repeat a piece of wisdom I got from ...   Jan 15 2025, 07:10 AM
Dave_Darling   So now I am going to ask you.. "What was the...   Jan 15 2025, 02:13 PM
Wew   Hi all, I have spark at all 4 cylinders. Spark p...   Jan 15 2025, 12:15 PM
914sgofast2   The "Car Wizard" channel on You Tube rec...   Jan 15 2025, 12:53 PM
Wew   The "Car Wizard" channel on You Tube re...   Jan 15 2025, 01:34 PM
Wew   I am also interested in your opinions of the link ...   Jan 15 2025, 01:33 PM
rjames   I am also interested in your opinions of the link...   Jan 15 2025, 01:56 PM
Wew   I recalibrated the throttle Position sensor in hop...   Jan 15 2025, 04:34 PM
Superhawk996   I disconnected the fuel injectors, the cold air ...   Jan 15 2025, 06:02 PM
emerygt350   Starter fluid is your friend.   Jan 15 2025, 05:52 PM
Wew   Thanks for the input. I have checked spark and hav...   Jan 15 2025, 11:57 PM
Superhawk996   The ballast resistor works against you when the en...   Jan 16 2025, 12:12 AM
Wew   I will add the ballast resistor back for better ru...   Jan 16 2025, 12:34 AM
Superhawk996   As I re-read this thread I don’t see anywhere th...   Jan 16 2025, 01:13 AM
Wew   Miracles do happen. It was the timing. I found a...   Jan 16 2025, 11:02 PM
emerygt350   Sounds like you need to try again with initial set...   Jan 17 2025, 06:18 AM
Shivers   Zoom-zoom :driving:   Jan 17 2025, 06:38 AM
15 User(s) are reading this topic (15 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 5th February 2025 - 01:06 PM
