> transmission questions?, sounds and humming?
mike914duck
post Jan 23 2025, 08:55 PM
sounds of the transmission humming or different sounds?
technicalninja
post Jan 23 2025, 10:18 PM
Another test is to get it up to speed where noise is loudest, depress clutch, shift to neutral.
Noise still present? Swing car L/R, depress brakes.
Turn engine off only 1 click. ABSOLUTELY do not engage steering lock.
That can be a WILD ride!
This turns the car into a glider. Noise still present?
Swing car left/right.
You can restart car before stopping by ignition on, release the clutch slowly in proper gear.
Yet another test. Determine RPM where noise is present. Hold that RPM in neutral stopped. Noise still present? engine related
Something SHOULD vary the noise.
No way any of us could diag with info you have provided so far...
Need more/better detailed info.
If I had to guess right now my money would be on a wheel bearing but I wouldn't make a monetary bet yet.
All the above test I would complete in less than 30 seconds...
Takes longer to type than DO!
(IMG:style_emoticons/default/ninja.gif)
mike914duck   transmission questions?   Jan 23 2025, 08:55 PM
jim_hoyland   Hi Mike, Tell us which gears the sound is prevalen...   Jan 23 2025, 09:09 PM
mike914duck   Hi Mike, Tell us which gears the sound is prevale...   Jan 23 2025, 09:43 PM
mike914duck   Hi Mike, Tell us which gears the sound is preval...   Jan 23 2025, 09:45 PM
technicalninja   Swing car right and left changing the load on each...   Jan 23 2025, 10:00 PM
technicalninja   Another test is to get it up to speed where noise ...   Jan 23 2025, 10:18 PM
rjames   Humming in 4th and 5th may be the intermediate pla...   Jan 23 2025, 11:33 PM
jim_hoyland   Humming in 4th and 5th may be the intermediate pl...   Jan 26 2025, 08:13 PM
rjames   Humming in 4th and 5th may be the intermediate p...   Jan 27 2025, 12:10 PM
jim_hoyland   There some good ideas for you. I took my car to a ...   Jan 24 2025, 07:32 AM
mike914duck   There some good ideas for you. I took my car to a...   Jan 24 2025, 10:18 AM
mlindner   I had a rear CV go last spring...after replacing b...   Jan 26 2025, 09:55 AM
Front yard mechanic   Get a better radio   Jan 27 2025, 08:27 AM
mlindner   Get a better radio What radio...no wipers, no h...   Jan 27 2025, 11:39 AM
Artfrombama   Following~~~~ My car has a similar noise, more not...   Jan 27 2025, 01:21 PM
Shivers   Following~~~~ My car has a similar noise, more no...   Jan 27 2025, 02:00 PM
rjames   Following~~~~ My car has a similar noise, more no...   Jan 27 2025, 04:50 PM
- Lo-Fi Version Time is now: 5th February 2025 - 11:56 AM
