> Derek’s Willow Green, ‘72 914, Restoration Thread
dereknlee
post May 24 2020, 11:26 PM
Inspired by others on this forum, this thread will document the restoration of my 1972 914 1.7.
I bought it in summer of 2008. It was supposed to be my daily driver that I would make minor improvements to while keeping it drivable. There was a memorable couple of weeks where I was using it for my commute in the winter, with no heat (heat ducting/valves removed for paint), and then the ignition switch went out and so I was parking at the top of hills until I got that figured out/fixed. I don't know how 914s got on my radar or what drew me to this car. Le Mans was, and is, one of my favorite movies - so I thought 1970s Porsches were cool. 911s were a bit out of reach, so I guess the 914 was the next closest option.
[Side note, cell phone camera technology has come a long way since 2008....and these pictures make me feel old.]
The plan for this car to be a daily driver changed (not so much by choice) when I bought a house in the fall, and upgraded from apartment carport to an actual garage. I set aside a couple weeks to drop the engine and tend to some oil leaks, and of course - discovered rust. The car hasn’t driven since (12 years as of this writing).
The worst of the rust was in the hell hole. I bought a MIG welder and did a fair job of patching things up. I also attacked the rust at the driverside jack point and in the rear trunk.
Then the house remodeling got serious. The car sat for four years before I decided I wasn’t going to learn body work and the car deserved better. I hired Eurotech Bodywerkes to finish the rust repair and repaint the car. When I bought it, the car had been re-sprayed (and poorly masked) in a John Deer green. The plan was to go back to the factory color: willow green.
Eurotech found more rust in the doors, so it got new doors. They also fit factory sway bars. They fixed miscellaneous rust all over the place, filled dings, re-sealed the seams, installed a new battery tray, stripped the underside, fitted new rocker panel valances, restored the old front and rear valences and then laid down a very pretty paint job. The cabin and front tank bay are the only areas with original paint.
At the same time I had the engine rebuilt by NW connecting rod into a 2ish L displacement (not sure as of this writing whether it is a 1911 or 2056) with a carb cam. The plan was to fit dual Webers (more on that later). I also had the transmission rebuilt to fix a chronic 1st gear grind. And I had some parts re-plated.
And then the car sat for six more years while I permitted and built/finished an addition to the house, as well as picked up some sports to occupy my time.
Spring forward to Dec 2018, and a freshly separated shoulder from a cycling crash. I started working on the 914 again. Re-sealed the tank (the kits available for this are amazing).
And refurbed the wiring loom in the front trunk:
...before getting side-tracked again by a Vanagon. The Vanagon was a 2018 acquisition that suddenly needed a motor replacement in 2019, following a catastrophic failure that occurred a few days after this picture was taken.
Which brings us to the current covid quarantine times and cancelled vanagon trips. But on the bright side, work has restarted on the 914 again. (IMG:style_emoticons/default/piratenanner.gif) Will this be the final push that sees the car on the road? Track record says no, but only time will tell.
I will add additional posts to document progress. But at the outset I’d like to state my intentions with the project I would like this to be a stock 914 (IMG:style_emoticons/default/prop.gif) - at least outwardly. This presents a dilemma relative to my current 2L engine. I'd like to coax as much performance out of the engine and 1.7 L Djet system as I can. But a new cam is in order to even consider that, and as long as the engine is coming apart then I can re-think heads and displacement - with the aim to go as big as possible without ditching everything for a 2.0 L Djet or going microsquirt.
-Derek
dereknlee
post Jan 30 2025, 11:52 PM
So since December I have made progress on a few fronts:
Wheels are done painting and ready to have tires mounted.
The 'cnc' brake line kit continued to disappoint, but I got all the lines in the rear installed. Only one of the five lines didn't need to be cut and re-flared to fit. My brake line flare kit was an estate sale find and initially I couldn't get it to make a flare, it would just push the line down in the die. To solve that problem I:
-chased the die threads with a tap.
-annealed the end of each line with a propane torch.
-used a liberal amount of anti-seize.
Once brake lines were fit, I installed the suspension. I found the hubs pressed in very easily using my bicycle headset press.
Obvious in retrospect, but I think the best order of operations for fitting the sway arm links is to press them onto the trailing bolt first (off the car, in a press) then install the bolt and press the bushing onto the sway bar ball with a C-clamp.
I still need to get some parking brake boots and clips.
Steering wheel refurb is coming along nicely. I have sanded and repainted and I am very impressed with how much better the leather looks. Waiting on the proper thread to arrive so I can re-do the stitching. That will be tedious. In the mean time, I might start cleaning up aft wiring harness and getting it re-routed through the chassis - would be nice to get it off the floor.
-Derek
dereknlee   Derek’s Willow Green, ‘72 914   May 24 2020, 11:26 PM
dereknlee   On to recent progress. In March I picked up where...   May 24 2020, 11:35 PM
dereknlee   I have accumulated a batch of parts that need to b...   May 24 2020, 11:44 PM
Cairo94507   Hi Derek- Wow. Great work and color. You are goi...   May 24 2020, 11:58 PM
wysri9   Great story which many of us can relate to......lo...   May 25 2020, 02:49 AM
luft   Great story which many of us can relate to......l...   May 25 2020, 04:59 AM
Big Len   Following......   May 25 2020, 06:05 AM
gereed75   Nice thread. Nice work. Nice car Git er done...   May 25 2020, 07:15 AM
tygaboy   Nice work. Your car looks great! Curious: whic...   May 25 2020, 07:16 AM
dereknlee   Thanks all for the encouragement! :beer2: ...   May 25 2020, 08:27 AM
dereknlee   Today I disassembled the other rear axle and degre...   May 25 2020, 07:46 PM
bkrantz   Keep up the momentum, Derek!   May 25 2020, 08:01 PM
billh1963   Great work! Looking forward to seeing more pro...   May 26 2020, 06:17 AM
jaredmcginness   Awesome work and thread. The fresh willow paint lo...   May 26 2020, 06:43 AM
dereknlee   Awesome work and thread. The fresh willow paint l...   May 26 2020, 07:23 AM
VaccaRabite   When I finally get around to installing my flares ...   May 26 2020, 08:02 AM
gereed75   Do what Mark said at the end of the other thread. ...   May 26 2020, 08:15 AM
rjames   Hey, I also live in Shoreline. Curious where you...   May 26 2020, 10:16 AM
mbseto   Nice work! Watching with interest...   May 26 2020, 01:44 PM
dereknlee   When I finally get around to installing my flares...   May 26 2020, 05:58 PM
flat4guy   Owning a Willow Green 914 as well I am enjoying th...   May 26 2020, 08:53 PM
djway   Car is looking good. When I was looking into cams ...   May 26 2020, 10:28 PM
dereknlee   Thanks guys. :beer2: When I spoke with Webcam ...   May 26 2020, 10:42 PM
bbrock   Hi Derek, I am loving your thread! Thanks for...   May 27 2020, 08:17 AM
dereknlee   Bit of a frustrating weekend, so I needed an easy ...   Jun 1 2020, 10:47 PM
bbrock   I wish I had space to spread my setup out a little...   Jun 2 2020, 07:59 AM
Chris H.   Looking great so far! Of all the great 914 co...   Jun 2 2020, 09:21 AM
dereknlee   Looking great so far! Of all the great 914 c...   Jun 2 2020, 07:12 PM
dereknlee   @bbrock Thank you for the advice! That give...   Jun 2 2020, 07:12 PM
bbrock   @[url=http://www.914world.com/bbs2/index.php?show...   Jun 2 2020, 09:52 PM
doug_b_928   As Brent said I've used both epsom salt/vinega...   Jun 3 2020, 05:02 PM
dereknlee   I may have to give caswell a try. I am happy with...   Jun 3 2020, 10:43 PM
dereknlee   Continued with the chromate bath development this ...   Jun 4 2020, 10:37 PM
Spoke   Car looks great. Nice chemistry set too.   Jun 4 2020, 10:47 PM
dereknlee   Plating update, and some actual car progress later...   Jun 7 2020, 08:56 PM
ben*james   Derek - Great thread. Nice to see all the work an...   Jun 7 2020, 09:17 PM
bbrock   Nice work overall and great progress on the platin...   Jun 7 2020, 09:46 PM
dereknlee   Thanks Ben! Your car is :drooley: Brent, ...   Jun 7 2020, 10:09 PM
PanelBilly   Everything looks so good. Don't worry if the c...   Jun 7 2020, 10:11 PM
dereknlee   Everything looks so good. Don't worry if the ...   Jun 7 2020, 10:46 PM
dereknlee   Installed new control arm bushings. The last one ...   Jun 9 2020, 09:59 PM
kroelofsen   Nice work, did it myself a few weeks ago. Now read...   Jun 10 2020, 12:41 AM
dereknlee   Got the rear bearings installed, and then spent so...   Jun 10 2020, 10:16 PM
bbrock   I wonder what the factory worker who slapped on t...   Jun 11 2020, 08:24 AM
JamesM   Love it! From a fellow :screwy: Here is ...   Jun 14 2020, 02:34 AM
bbrock   Love it! From a fellow :screwy: Here is...   Jun 14 2020, 11:16 AM
dereknlee   Looks good Brent! I assume these were some so...   Jun 13 2020, 10:45 PM
dereknlee   Whoever wielded the K stamp worked on a lot of car...   Jun 14 2020, 08:05 PM
flat4guy   Love reading your thread - makes me feel lazy with...   Jun 14 2020, 08:53 PM
dereknlee   Love reading your thread - makes me feel lazy wit...   Jun 14 2020, 10:25 PM
dereknlee   Been a busy few years, but sadly not on the 914. ...   Feb 25 2024, 09:23 PM
dereknlee   Don't recall what specifically stalled out pro...   Nov 27 2024, 10:41 PM
dereknlee   Front suspension and brakes are done. On to the...   Dec 8 2024, 09:49 PM
dereknlee   So since December I have made progress on a few fr...   Jan 30 2025, 11:52 PM
jd74914   Clever use of a headset press!   Jan 31 2025, 08:52 AM
Cairo94507   Excellent work Derek. :beer2:   Jan 31 2025, 08:55 AM
dereknlee   Rear wire bundle is re-taped and routed back throu...   Feb 2 2025, 11:36 PM
Dion   Nice to see you back at it. Looks great.   Feb 3 2025, 07:28 AM
dereknlee   Few weeks of progress update: After collecting th...   Mar 5 2025, 10:10 PM
Cairo94507   Coming along nicely. :beer2:   Mar 6 2025, 09:53 AM
friethmiller   :popcorn:   Mar 6 2025, 09:57 AM
- Lo-Fi Version Time is now: 14th March 2025 - 11:32 AM
