> 916 chassis
Montreal914
post Feb 1 2025, 06:08 PM
Were the few 916's equipped with the GT stiffening kit?
Other than the obvious rigid roof, were there any chassis stiffening improvement to handle the larger powertrain/gearbox?
technicalninja
post Feb 3 2025, 11:01 AM
QUOTE(Montreal914 @ Feb 3 2025, 09:39 AM) *
Thank you TMM914, Marty, Rory, Dave, and Bob. (IMG:style_emoticons/default/sunglasses.gif)
Reinforcement of the A-pillar maybe, other exclusive 916 reinforcement mods?
Interesting to see that Brutus did not have any visible reinforcement of the trailing arms and suspension ears.
Current plan:
- Inner Maddogs kit
- Outer RD clamshell
- GT kit
Thinking potentially:
- Suspension ears reinforcement
- Inner ear heim joint rod to firewall
- Outer heim joint rod for alignment adjustment and maintain
- Rear trailing arm bulhead plate (Chris Foley's trailing arm reinforcement design)
- Some rear suspension tower seam stich welding
I might be overthinking this, but a 3.2 and a 916 box is a very different setup compared to a VW bus engine.
Your list is very close to mine...
I'm for more seam welding and further rear mods.
The 914 V8 guy Renegade Hybrids had a simple rear ear mod that I'm going to incorporate with your above list.
Had I been you I'd have kept those front sway bar mount reinforcement plates you sold to Fred. I liked those...
I'll do a little bit of front pan re-enforcement and increase the strength of the top mounts for the front struts.
As I'm planning on keeping the removable top, I'm not planning on working the A-pillars.
I believe a roll bar similar to Tygaboy's V8 car is the way to go on an open top car.
I'll be re-enforcing my car for 300lbs./ft. and 350 rwhp. I will not be using a Porsche 6.
Current candidates are a blown K20 (lightweight) or (more likely) a GM LGX 3.6L V6.
Current tranny choice is Boxster 6 speed (and Tygaboy's steam punk shifter!).
Montreal914   916 chassis   Feb 1 2025, 06:08 PM
TMM914   Here is a shot of the 916 at Canepa that you can s...   Feb 1 2025, 08:36 PM
dr914@autoatlanta.com   funny the transmission round plates are on the wro...   Feb 3 2025, 05:57 PM
rgalla9146   [quote name='dr914@autoatlanta.com' post=...   Feb 3 2025, 08:11 PM
Maltese Falcon   For some reason those cup washers /transaxle mount...   Feb 1 2025, 08:44 PM
davep   But I think that with the 916 hot rod 2.4 mfi, th...   Feb 2 2025, 08:21 PM
TMM914   But I think that with the 916 hot rod 2.4 mfi, t...   Feb 3 2025, 03:27 PM
Maltese Falcon   This is how the 916 nose cone transaxle mounting h...   Feb 1 2025, 09:17 PM
rgalla9146   This is how the 916 nose cone transaxle mounting ...   Feb 2 2025, 08:09 AM
Maltese Falcon   This is how the 916 nose cone transaxle mounting...   Feb 2 2025, 10:08 AM
Maltese Falcon   @Montreal if you have a bit of time during your 4 ...   Feb 2 2025, 11:16 PM
Maltese Falcon   Master exhaust header fabricator EujeƱio was so p...   Feb 2 2025, 11:21 PM
Maltese Falcon   Good times at this track, just needed a taller 5th...   Feb 2 2025, 11:26 PM
burton73   Here are several photos of the reinforcement that ...   Feb 3 2025, 09:07 AM
Montreal914   Thank you TMM914, Marty, Rory, Dave, and Bob. B:)...   Feb 3 2025, 09:39 AM
930cabman   These chassis mods (meant to stiffen) are great, b...   Feb 3 2025, 10:27 AM
technicalninja   Thank you TMM914, Marty, Rory, Dave, and Bob. B:...   Feb 3 2025, 11:01 AM
Maltese Falcon   @Montreal914 you can always come by* + visit the...   Feb 3 2025, 11:18 AM
davep   OH, 9141430195 is Brutus, the prototype, so, close...   Feb 3 2025, 04:03 PM
Cairo94507   I really went back and forth on stiffening modific...   Feb 3 2025, 05:21 PM
ClayPerrine   I was always under the impression the big cupped w...   Feb 4 2025, 07:12 AM
Montreal914   So it looks like the concensus on the 916 is: - W...   Feb 4 2025, 09:19 AM
- Lo-Fi Version Time is now: 5th February 2025 - 06:50 AM
