SWH |
Newbie ![]() Group: Members Posts: 12 Joined: 27-April 24 From: Arizona Member No.: 28,084 Region Association: Southwest Region ![]() |
Completed rebuild on 1974 914 2.0 L. All fuel and vacuum lines are also new. Engine idle varies between 1000 and 2000 rpm every few seconds what could cause this?
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,894 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Did you rebuild the throttle body?
Most of them are worn creating a vacuum leak Also worth servicing the distributor Or just replacing with 123 |
ctc911ctc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,057 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States ![]() ![]() |
Did you rebuild the throttle body? Most of them are worn creating a vacuum leak Also worth servicing the distributor Or just replacing with 123 (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) Start here - this is the foundation of all things DJet |
worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,455 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
Did you rebuild the throttle body? Most of them are worn creating a vacuum leak Also worth servicing the distributor Or just replacing with 123 (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) Start here - this is the foundation of all things DJet I hope that you will expand on your answer. How do the dizzy and throttle body feed into this? Anything that I can learn about the little fellers is a bonus. Thanks. |
brant |
Dup
Lo-Fi Version | Time is now: 14th March 2025 - 12:12 PM |
