fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
Doesn't appear to be causing a problem, just never seen (looked?) it before. Had an OBD II scanner hooked up which also does real time monitoring. Was driving around and noticed that stopped/at idle, rpm was 750-800 and spark advance was -15 (15 ATDC?). Normal around town it runs about 2000rpm and +15, peaking to +20/25 at 3000.
Redline is about 5000, haven't pushed it near that. Also noticed when backing off, even at 1500/2000, the advance will go negative. Is this all part of the computer controlled emissions system? |
fixer34 |
Thanks guys, figured it was 'normal' since there weren't any codes and it seemed to run fine. I just never remembered ever setting timing for ATDC, but then again, that was back when cars had distributors...
Lo-Fi Version | Time is now: 14th March 2025 - 11:21 AM |
