> Idle fluctuation, Rpm between 1000 and 2000
SWH
post Feb 5 2025, 11:18 PM
Completed rebuild on 1974 914 2.0 L. All fuel and vacuum lines are also new. Engine idle varies between 1000 and 2000 rpm every few seconds what could cause this?
SWH
post Feb 9 2025, 12:53 PM
Thank for all the feedback on the idle searching problem. The searching starts as the cold idle ends. The fluctuation is back and forth every few seconds. I have not driven since rebuild. Only did the cam break in. I did clean the throttle body and distributor, but did not do any rebuilds on these items. I did just complete brake system rebuild and should be able to drive soon. Some had mentioned the rubber vacuum which is new. I also tried adjusting the ECU, but not sure of the proper techniqueAttached Image
SWH   Idle fluctuation   Feb 5 2025, 11:18 PM
brant   Did you rebuild the throttle body? Most of them a...   Feb 6 2025, 07:34 AM
ctc911ctc   Did you rebuild the throttle body? Most of them ...   Feb 6 2025, 07:59 AM
worn   Did you rebuild the throttle body? Most of them...   Feb 6 2025, 06:46 PM
brant   [quote name='ctc911ctc' post='3190563' date='Feb ...   Feb 7 2025, 03:55 PM
brant   Dup   Feb 7 2025, 04:12 PM
76-914   [quote name='ctc911ctc' post='3190563' date='Feb...   Feb 7 2025, 05:07 PM
TJB/914   [quote name='brant' date='Feb 6 2025, ...   Feb 6 2025, 04:21 PM
emerygt350   That is interesting, there are not any feedback me...   Feb 6 2025, 11:29 AM
VaccaRabite   I'm going to go with throttle body as the prim...   Feb 6 2025, 01:59 PM
rhodyguy   Known as ‘hunting’? Up and down? Examine the s...   Feb 6 2025, 02:06 PM
914sgofast2   You have an uncontrolled vacuum leak somewhere dow...   Feb 6 2025, 02:18 PM
ctc911ctc   You have an uncontrolled vacuum leak somewhere do...   Feb 6 2025, 02:47 PM
emerygt350   Hunting normally isn't the result of a vacuum ...   Feb 6 2025, 06:53 PM
brant   I hope you’re doing GREAT. Kent It’s been a w...   Feb 7 2025, 07:01 PM
emerygt350   I would go with a leak like brant described if it ...   Feb 7 2025, 09:35 PM
saigon71   A hunting idle can also be caused by a lean idle m...   Feb 8 2025, 06:59 AM
emerygt350   A hunting idle can also be caused by a lean idle ...   Feb 8 2025, 11:06 AM
JamesM   A hunting idle can also be caused by a lean idle ...   Feb 10 2025, 10:28 PM
SWH   Thank for all the feedback on the idle searching p...   Feb 9 2025, 12:53 PM
ctc911ctc   Beautiful Paint Job - do you have a color number? ...   Feb 9 2025, 02:47 PM
emerygt350   remind me, was it modded at all? I bet you are ju...   Feb 9 2025, 02:32 PM
Fazasport   Can anyone reccomend someone who is currently rebu...   Feb 10 2025, 04:13 PM
emerygt350   Can anyone reccomend someone who is currently reb...   Feb 10 2025, 05:53 PM
steuspeed   I had a hunting idle and it went away when I repla...   Feb 10 2025, 11:55 PM
- Lo-Fi Version Time is now: 14th March 2025 - 12:16 PM
