SteveNMaine |
Newbie ![]() Group: Members Posts: 33 Joined: 12-August 24 From: Maine Member No.: 28,288 Region Association: None ![]() |
Hey, has anyone restored the compressed shape of a 914 thermostat? The one I have has expanded and does not appear to have any leaks.
I have removed the solder on the threaded end which revealed a ball bearing. I removed the ball bearing and tested for leaks by compressing the unit and plugging the hole. It kept the semi-compressed shape for several hours and when I removed the plug, air rushed in and it expanded again. Is there a way to restore it to its completely compressed shape at idle so-to-speak? |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,225 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
And if you do use them, please check them to make sure they work. Having the flaps stay closed could potentially ruin your engine.
So with the flaps connected, use a heat gun to warm up the thermostat and make sure the flaps open up fully. |
Lo-Fi Version | Time is now: 3rd April 2025 - 12:15 PM |
