Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,729 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
OK, once more with feeling….
This is the 74 that had the misrouted accelerator cable. That has been removed so now I have what I believe is the original accelerator cable, the arrow is pointing at it, which is good in stock in the tunnel. Even with vice grips on it, I can’t pull it out and it doesn’t really wanna move forward either. I’m going to have to remove this before I install replacement cable so any ideas or suggestions? ![]() |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,224 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
That's not the hole for the accelerator cable. That's the hole for the heater control valve cable. You can tell because it is flared on the end. The accelerator cable tube is not flared and is lower to the left.
The heater cable removes from the inside, as it is a U shaped cable. You have to remove the heater control lever and pull it out to get the cable out. |
Lo-Fi Version | Time is now: 2nd April 2025 - 07:07 PM |
