Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,729 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
OK, once more with feeling….
This is the 74 that had the misrouted accelerator cable. That has been removed so now I have what I believe is the original accelerator cable, the arrow is pointing at it, which is good in stock in the tunnel. Even with vice grips on it, I can’t pull it out and it doesn’t really wanna move forward either. I’m going to have to remove this before I install replacement cable so any ideas or suggestions? ![]() |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,224 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
And I will add that is definitely not the throttle cable. It is a stranded cable. That is a solid wire used for the heater control valves.
The throttle cable is the one above the speedometer cable and to the left of the wire snorkel in the picture. |
Lo-Fi Version | Time is now: 2nd April 2025 - 07:13 PM |
