> Idle fluctuation, Rpm between 1000 and 2000
SWH
post Feb 5 2025, 11:18 PM
Completed rebuild on 1974 914 2.0 L. All fuel and vacuum lines are also new. Engine idle varies between 1000 and 2000 rpm every few seconds what could cause this?
saigon71
post Feb 8 2025, 06:59 AM
A hunting idle can also be caused by a lean idle mixture.
Try rotating the mixture knob on the ECU full clockwise and see if it makes a difference.
JamesM
post Feb 10 2025, 10:28 PM
QUOTE(saigon71 @ Feb 8 2025, 05:59 AM) *
^^^That
But I suspect it is just part of the problem and there are multiple contributing factors.
D-jet idle can be sort of tricky where you have to chase multiple variables simultaneously to get it just right.
My suspicion is you have a combination of ALL the following happening at the same time to some extent.
1. Intake air leak(s)
2. Lean mixture
3. A worn out distributor. or possibly the wrong distributor or misadjusted timing.
I would start by checking the timing and verifying that your vacuum retard is functioning properly. 74 2.0s absolutely require proper functioning vacuum retard to idle properly. Next check what the timing is doing when it is hunting. If you have weak advance springs a small air leak can be enough to get you up to speed to where a bunch of unintended ignition advance then revs you up even higher, at least until it starves itself and drops back down.
long story short, with d-jet you sort of have to check everything, but start with timing and then air leaks.
SWH   Idle fluctuation   Feb 5 2025, 11:18 PM
brant   Did you rebuild the throttle body? Most of them a...   Feb 6 2025, 07:34 AM
ctc911ctc   Did you rebuild the throttle body? Most of them ...   Feb 6 2025, 07:59 AM
worn   Did you rebuild the throttle body? Most of them...   Feb 6 2025, 06:46 PM
brant   [quote name='ctc911ctc' post='3190563' date='Feb ...   Feb 7 2025, 03:55 PM
brant   Dup   Feb 7 2025, 04:12 PM
76-914   [quote name='ctc911ctc' post='3190563' date='Feb...   Feb 7 2025, 05:07 PM
TJB/914   [quote name='brant' date='Feb 6 2025, ...   Feb 6 2025, 04:21 PM
emerygt350   That is interesting, there are not any feedback me...   Feb 6 2025, 11:29 AM
VaccaRabite   I'm going to go with throttle body as the prim...   Feb 6 2025, 01:59 PM
rhodyguy   Known as ‘hunting’? Up and down? Examine the s...   Feb 6 2025, 02:06 PM
914sgofast2   You have an uncontrolled vacuum leak somewhere dow...   Feb 6 2025, 02:18 PM
ctc911ctc   You have an uncontrolled vacuum leak somewhere do...   Feb 6 2025, 02:47 PM
emerygt350   Hunting normally isn't the result of a vacuum ...   Feb 6 2025, 06:53 PM
brant   I hope you’re doing GREAT. Kent It’s been a w...   Feb 7 2025, 07:01 PM
emerygt350   I would go with a leak like brant described if it ...   Feb 7 2025, 09:35 PM
saigon71   A hunting idle can also be caused by a lean idle m...   Feb 8 2025, 06:59 AM
emerygt350   A hunting idle can also be caused by a lean idle ...   Feb 8 2025, 11:06 AM
JamesM   A hunting idle can also be caused by a lean idle ...   Feb 10 2025, 10:28 PM
SWH   Thank for all the feedback on the idle searching p...   Feb 9 2025, 12:53 PM
ctc911ctc   Beautiful Paint Job - do you have a color number? ...   Feb 9 2025, 02:47 PM
emerygt350   remind me, was it modded at all? I bet you are ju...   Feb 9 2025, 02:32 PM
Fazasport   Can anyone reccomend someone who is currently rebu...   Feb 10 2025, 04:13 PM
emerygt350   Can anyone reccomend someone who is currently reb...   Feb 10 2025, 05:53 PM
steuspeed   I had a hunting idle and it went away when I repla...   Feb 10 2025, 11:55 PM
- Lo-Fi Version Time is now: 14th March 2025 - 12:17 PM
