> Original accelerator cable stuck in tunnel - any ideas?
Tdskip
post Feb 10 2025, 02:12 PM
OK, once more with feeling….
This is the 74 that had the misrouted accelerator cable. That has been removed so now I have what I believe is the original accelerator cable, the arrow is pointing at it, which is good in stock in the tunnel.
Even with vice grips on it, I can’t pull it out and it doesn’t really wanna move forward either.
I’m going to have to remove this before I install replacement cable so any ideas or suggestions?
Craigers17
post Feb 13 2025, 05:33 PM
Just for shits and grins, have you tried to run something through the tube that has a little less girth? I'd be interested to see if you could push something smaller through there and actually physically see it or grab it at the accelerator end of the tunnel. This would at least give you a good idea if the thing was still all together and mostly "open". If so, you'd have a good idea that, as previously mentioned, maybe the end is just a little corroded, out of round, etc.
Tdskip
post Feb 13 2025, 08:12 PM
QUOTE(Craigers17 @ Feb 13 2025, 06:33 PM) *
I did get a coat hanger into the opening and it seemed ok. Will try something a big larger.
I think the tube is slightly collapsed near the opening.
Thanks for the suggestion!
Tdskip   Original accelerator cable stuck in tunnel - any ideas?   Feb 10 2025, 02:12 PM
ClayPerrine   That's not the hole for the accelerator cable....   Feb 10 2025, 02:19 PM
Craigers17   Disregard based on Clay’s answer.   Feb 10 2025, 02:21 PM
ClayPerrine   And I will add that is definitely not the throttle...   Feb 10 2025, 02:25 PM
Tdskip   Oh man? This poor car and somewhat clueless curren...   Feb 10 2025, 02:35 PM
ClayPerrine   Oh man? This poor car and somewhat clueless curre...   Feb 10 2025, 03:59 PM
Jamie   Oh man? This poor car and somewhat clueless curr...   Feb 10 2025, 08:47 PM
Tdskip   The replacement accelerator cable won’t fit into...   Feb 10 2025, 03:09 PM
BillC   The replacement accelerator cable won’t fit int...   Feb 11 2025, 01:22 PM
Tdskip   Seems like the same of seething is still stuck in ...   Feb 10 2025, 03:11 PM
Tdskip   Thanks Clay, appreciate all the help.   Feb 10 2025, 04:01 PM
rjames   I can't remember how long the tube from the fi...   Feb 10 2025, 05:05 PM
Tdskip   Thanks Robert. I’m sure there will be other issu...   Feb 10 2025, 06:13 PM
Dave_Darling   Photos of what is inside the tunnel can be found h...   Feb 10 2025, 07:44 PM
rjames   Photos of what is inside the tunnel can be found ...   Feb 10 2025, 09:23 PM
aturboman   I ran into the same issue once on a car that sat f...   Feb 11 2025, 10:41 AM
Tdskip   Oh wow, good catch. I really appreciate the time y...   Feb 11 2025, 06:32 PM
Tdskip   OK - One step forward,one step on hold. Removed t...   Feb 13 2025, 02:16 PM
sixnotfour   Slide a Phillips screw driver and wooble it around...   Feb 13 2025, 04:19 PM
Tdskip   Slide a Phillips screw driver and wooble it aroun...   Feb 13 2025, 08:11 PM
Craigers17   Just for shits and grins, have you tried to run so...   Feb 13 2025, 05:33 PM
Tdskip   Just for shits and grins, have you tried to run s...   Feb 13 2025, 08:12 PM
PlaysWithCars   Slide a Phillips screw driver and wooble it aroun...   Feb 14 2025, 06:43 PM
Tdskip   Philips head wobble technique didn’t work (or at...   Mar 23 2025, 11:32 AM
Superhawk996   Should I get power to the drill bit to see if I ...   Mar 23 2025, 12:05 PM
Tdskip   Should I get power to the drill bit to see if I...   Mar 23 2025, 12:07 PM
Superhawk996   Be aware there is a lot of variance in how and whe...   Mar 23 2025, 12:13 PM
Tdskip   Any chance the replacement cables have larger fitt...   Mar 25 2025, 06:28 PM
Superhawk996   Any chance the replacement cables have larger fit...   Mar 26 2025, 07:31 AM
Ron914   Good morning Tom , @Tdskip I found these photos ...   Mar 26 2025, 07:05 AM
Ron914   and two more   Mar 26 2025, 07:07 AM
Tdskip   Thanks for all of the replies and attempts to help...   Mar 26 2025, 12:44 PM
Tdskip   Should I try very minimally shaving/grinding a bit...   Mar 26 2025, 12:51 PM
Ron914   You probably don't remember me Tom but I purch...   Mar 26 2025, 12:56 PM
Tdskip   You probably don't remember me Tom but I purc...   Mar 26 2025, 01:25 PM
Ron914   You probably don't remember me Tom but I pur...   Mar 26 2025, 01:31 PM
Tdskip   OK - got it! In the end it was the tube being...   Mar 26 2025, 01:08 PM
914werke   Should I try very minimally shaving/grinding a bi...   Mar 26 2025, 04:12 PM
Dlee6205   Should I try very minimally shaving/grinding a b...   Mar 26 2025, 06:06 PM
Superhawk996   :headbanger: Glad you got it :trophy:   Mar 26 2025, 06:52 PM
Tdskip   Hope this thread helps others facing similar issue...   Mar 27 2025, 05:42 AM
930cabman   Hope this thread helps others facing similar issu...   Mar 27 2025, 11:09 AM
Ron914   Glad you got it through finally . These treads alw...   Mar 27 2025, 07:20 AM
Root_Werks   Dang, that's one I haven't encountered bef...   Mar 27 2025, 01:18 PM
914werke   Reminded me... Heres one. OG cable came out of the...   Mar 28 2025, 05:43 PM
Superhawk996   Turned out a PO's errant sheet metal screw h...   Mar 28 2025, 06:04 PM
914werke   Turned out a PO's errant sheet metal screw h...   Mar 28 2025, 07:38 PM
Superhawk996   I like the creativity of the brazed drill bit solu...   Mar 28 2025, 10:43 PM
- Lo-Fi Version Time is now: 2nd April 2025 - 07:10 PM
