sdoolin |
Member ![]() ![]() Group: Members Posts: 414 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None ![]() |
Rebuilding(ish) my 2056. On my first build I was able to achieve a compression ratio of very nearly 9.0:1. With this build, I am having to add .020 spacers below the jugs to get any measurable deck height in the jugs. I am calculating a compression ratio of 8.6:1.
Will I notice the loss in compression ratio? |
sdoolin |
I have measured all of the shims I have on hand (6 of them). They are - .0115, .0115, .012, .012, .014 & .015. My dial indicator and I had some long conversations today about positioning as I see fit, and I believe I came out on top. Will have the magnetic base on the flywheel, dial indicator tip on the case.
I'm gonna install the 2 thinnest shims I have, bolt up the flywheel and measure (again). After the snowstorm comes and goes... ![]() |
Lo-Fi Version | Time is now: 12th March 2025 - 02:17 PM |
