sdoolin |
Member ![]() ![]() Group: Members Posts: 414 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None ![]() |
Rebuilding(ish) my 2056. On my first build I was able to achieve a compression ratio of very nearly 9.0:1. With this build, I am having to add .020 spacers below the jugs to get any measurable deck height in the jugs. I am calculating a compression ratio of 8.6:1.
Will I notice the loss in compression ratio? |
Jack Standz |
Member ![]() ![]() Group: Members Posts: 474 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() ![]() |
Add a cable from the negative side of the battery to the ground strap/bolt on the transmission.
Then attach a remote starter switch like this one, make your own, or use a heavy enough gauge wire to momentarily engage the starter. https://www.amazon.com/INNOVA-3630-Remote-S...C176&sr=8-4 |
Lo-Fi Version | Time is now: 12th March 2025 - 02:27 PM |
