> Front tires rubbing inside in tight turns
SVG223
post Feb 19 2025, 08:47 PM
195/65/15 Stock Fuchs. Turning radius restricted. Just parking, and U-turns. Would a 1/2" wheel spacer help?
Geezer914
post Feb 22 2025, 08:04 AM
Geezer914
It looks like your upper camber plate bushings are worn???
Superhawk996
post Feb 22 2025, 12:18 PM
QUOTE(Geezer914 @ Feb 22 2025, 10:04 AM) *
(IMG:style_emoticons/default/agree.gif) With both Geezer and SirAndy - upper mounts don’t look right.
There is supposed to be a metal sleeve in the center of the bushing. Almost looks as if you may be lacking that metal sleeve and it’s allowing a lot of movement of the strut rod.
SVG223
post Feb 22 2025, 03:00 PM
QUOTE(Superhawk996 @ Feb 22 2025, 12:18 PM) *
Oh wow! If that is the case, that will fix many issues. I will see if I can order a stainless steel pipe of the right dimensions. Thanks, guys!
SVG223
post Feb 22 2025, 05:01 PM
QUOTE(SVG223 @ Feb 22 2025, 03:00 PM) *
Here is a picture with the nut off. I'm going to look for pictures to compare.
Superhawk996
post Feb 22 2025, 07:02 PM
QUOTE(SVG223 @ Feb 22 2025, 07:01 PM) *
Little hard to tell from the picture but I think it is there (red arrow)
You can double check by sticking a magnet to the inner part of the bushing assuming it it’s there like it appears.
Good to verify it like you are though - sure looks a little wonky in the initial pictures that the guys commented on.
Once you put the washer and but back on verify there is no slop. Attached Image
L-Jet914
post Feb 22 2025, 09:31 PM
QUOTE(Superhawk996 @ Feb 22 2025, 05:02 PM) *
You mentioned 185s. What aspect ratio of 185s would you recommend. I currently have 195/65R15 on my wheels currently.
SVG223   Front tires rubbing inside in tight turns   Feb 19 2025, 08:47 PM
bkrantz   What are your camber and caster settings?   Feb 19 2025, 08:54 PM
SVG223   What are your camber and caster settings? Got no...   Feb 19 2025, 09:00 PM
mgp4591   I'd think a 195/65 sounds a little tall. Stock...   Feb 19 2025, 09:24 PM
SVG223   I'd think a 195/65 sounds a little tall. Stoc...   Feb 19 2025, 09:55 PM
mgp4591   I'd think a 195/65 sounds a little tall. Sto...   Feb 19 2025, 10:22 PM
gonzo54   I have the same size tires with no interference/ru...   Feb 19 2025, 09:25 PM
SVG223   I have the same size tires with no interference/r...   Feb 19 2025, 09:42 PM
mgp4591   Oops, double post,   Feb 19 2025, 09:25 PM
SVG223   After considering the questions posed by @bkrantz...   Feb 19 2025, 10:07 PM
mepstein   I’ve ran 195x65x15 with 2.0 Fuchs on quite a few...   Feb 20 2025, 04:08 AM
burton73   Are you saying in a parking situation super tight ...   Feb 20 2025, 02:32 PM
SVG223   Are you saying in a parking situation super tight...   Feb 20 2025, 04:28 PM
burton73   Best Bob B Just parking, and U-turns. I don...   Feb 21 2025, 02:27 PM
SirAndy   That doesn't look right. Does your car show ...   Feb 20 2025, 03:45 PM
SVG223   That doesn't look right. Does your car show...   Feb 20 2025, 04:32 PM
SirAndy   That doesn't look right. Does your car sho...   Feb 20 2025, 04:42 PM
SVG223   [quote name='SVG223' post='3192787' date='Feb 20 ...   Feb 20 2025, 05:06 PM
SVG223   Strut tower for vague alignment reference. It look...   Feb 20 2025, 04:39 PM
SirAndy   The good news, your fenders look fine. However, ...   Feb 20 2025, 07:30 PM
SVG223   The good news, your fenders look fine. However,...   Feb 20 2025, 08:00 PM
SirAndy   The good news, your fenders look fine. However, ...   Feb 20 2025, 08:05 PM
SVG223   [quote name='SVG223' post='3192807' date='Feb 20 ...   Feb 20 2025, 08:28 PM
SirAndy   I see an area in the fender well where the tire ha...   Feb 20 2025, 08:34 PM
SVG223   I see an area in the fender well where the tire h...   Feb 20 2025, 09:02 PM
Front yard mechanic   I think I have a solution :idea: if you want to d...   Feb 20 2025, 09:26 PM
SVG223   I think I have a solution :idea: if you want to ...   Feb 20 2025, 09:46 PM
Dave_Darling   This is common with 195-width or wider tires. Mos...   Feb 21 2025, 03:57 PM
SVG223   This is common with 195-width or wider tires. Mo...   Feb 21 2025, 10:48 PM
Superhawk996   This is common with 195-width or wider tires. ...   Feb 22 2025, 12:26 PM
SVG223   Now I'm thinking about having my alignment cha...   Feb 21 2025, 11:37 PM
Superhawk996   I'm curious about the setup others have with...   Feb 22 2025, 12:00 PM
SVG223   I'm curious about the setup others have wit...   Feb 22 2025, 12:23 PM
Geezer914   It looks like your upper camber plate bushings are...   Feb 22 2025, 08:04 AM
Superhawk996   It looks like your upper camber plate bushings ar...   Feb 22 2025, 12:18 PM
SVG223   It looks like your upper camber plate bushings a...   Feb 22 2025, 03:00 PM
SVG223   [quote name='Superhawk996' post='3193103' date='F...   Feb 22 2025, 05:01 PM
Superhawk996   Here is a picture with the nut off. I'm goin...   Feb 22 2025, 07:02 PM
L-Jet914   [quote name='SVG223' post='3193128' date='Feb 22 ...   Feb 22 2025, 09:31 PM
Superhawk996   You mentioned 185s. What aspect ratio of 185s wou...   Feb 23 2025, 12:20 AM
rhodyguy   Avoiding turning the steering wheel to ‘full loc...   Feb 22 2025, 03:32 PM
SVG223   I just ordered (2) 10mm spacers and 20 chromed 45m...   Feb 23 2025, 12:20 AM
25 User(s) are reading this topic (24 Guests and 0 Anonymous Users)
1 Members: SVG223
- Lo-Fi Version Time is now: 23rd February 2025 - 03:56 PM
