> CV Joint Comparison Info, Good To Know
914Sixer
post Feb 23 2025, 10:11 AM
Thought I would post this up. From what I am seeing, the VW bus 100mm CV should be a direct bolt on with NO machining on stock 914 shaft like the 944 CV requires Should work with 911SC flanges and stub axle. The 17 degree angle should have NO bearing on stock use since 914 is 12 degrees.
Click to open chart.
jim_hoyland
post Feb 23 2025, 05:57 PM
Get that VIN ?
Who sells the bus 100mm CVs ? And, do they require any further modification to replace a 914 CV ?
- Lo-Fi Version Time is now: 26th February 2025 - 05:12 PM
