> Sway Bar Question
Osnabruck914
post Feb 18 2025, 05:49 PM
Well, the other day I noticed my '74 2.0 had something dangling underneath. Sure enough, those cheap nylon rear sway bar downlink bushings had failed again. I did not have any replacement bushings on hand, and with a car show coming up the next day, I just decided to remove the whole rear sway bar assembly until I could order and receive new bushings.
Driving without the rear sway bar, I was surprised to note that the car felt lighter and more responsive at the wheel. What's going on here? I thought having both bars was always a better option. Is it a psychological thing or is it real. Should I leave the rear bar off? I do not drive that aggressively nor do I autocross or rally.
I have read that it is not Kosher to drive with only a rear bar installed, but OK with just the front. Is that true?
Osnabruck914
Justinp71
post Feb 27 2025, 09:34 PM
I've never run a rear bar on my six conv, never felt I needed it. And I've done a few autocrosses and track days. I will say I went from 205's to 225's in the back and it helped the car feel a lot more neutral, before that it could easily oversteer but it also used to have stiffer rear springs. Running 200lb rear springs now.
Osnabruck914   Sway Bar Question   Feb 18 2025, 05:49 PM
Shivers   I know some owners here run a front bar only. Some...   Feb 18 2025, 06:21 PM
morehills   My car feels great without a rear sway bar. Less w...   Feb 18 2025, 07:28 PM
Superhawk996   Complex answer. It is partially psychological. ...   Feb 18 2025, 07:35 PM
sixaddict   I have run a 914-6/for longer than I would like to...   Feb 18 2025, 07:59 PM
Superhawk996   Had this in another thread but equally relevant he...   Feb 18 2025, 08:42 PM
bkrantz   Had this in another thread but equally relevant h...   Feb 26 2025, 09:16 PM
Osnabruck914   I really appreciate all the great replies and info...   Feb 18 2025, 08:53 PM
ClayPerrine   I will say this first: It's your car. If you...   Feb 19 2025, 06:32 AM
sixaddict   Not to beg the question because Clay is smarter th...   Feb 19 2025, 08:45 AM
jcd914   Not to beg the question because Clay is smarter t...   Feb 22 2025, 01:19 AM
Superhawk996   We did not have a standard set-up, every set up w...   Feb 22 2025, 07:32 AM
Superhawk996   Here’s the thing, any discussion of bars vs no b...   Feb 19 2025, 09:19 AM
Olympic 914   I know some of the Jeep guys run a front sway bar ...   Feb 19 2025, 12:27 PM
Geezer914   What rear springs are you running? My set up is 1...   Feb 19 2025, 12:54 PM
ClayPerrine   I will ad this. You can run no bar in the rear. ...   Feb 19 2025, 01:09 PM
sixaddict   That is very true and probably makes ride much bet...   Feb 19 2025, 06:17 PM
rfinegan   I'm running 120 rear and the factory rear bar....   Feb 19 2025, 01:53 PM
Olympic 914   I'm running 120 rear and the factory rear bar...   Feb 19 2025, 02:12 PM
technicalninja   Well, the other day I noticed my '74 2.0 had ...   Feb 19 2025, 04:54 PM
dr914@autoatlanta.com   without the rear bar the car understeers which is ...   Feb 19 2025, 05:24 PM
Osnabruck914   Well, the new bushings arrived so I decided to re-...   Feb 26 2025, 04:00 PM
Justinp71   I've never run a rear bar on my six conv, neve...   Feb 27 2025, 09:34 PM
- Lo-Fi Version Time is now: 14th March 2025 - 01:14 PM
