> Into the Tunnel, Last chance to see before we button it up
zoomCat
post Mar 7 2025, 12:32 PM
Here's a view of the tunnel from the bottom with no floor pans:
This is an early car with a side shift conversion, stainless fuel lines, and the 914/6 hand throttle. The speedometer, throttle, and heater cables have not been installed.
I'll be adding a few more photos, but I'm putting these up with high resolution and only get one per post.
ClayPerrine
post Mar 7 2025, 03:50 PM
QUOTE(zoomCat @ Mar 7 2025, 12:50 PM) *
A better shot of the hand throttle:
And the business end:
Note that the bushing and nubbin on the end are missing here. I have put in a simple grommet to keep it from rattling around, but I'm looking for the real thing or a suitable substitute. Aase has NOS nubbins, yay!
For the end of the hand throttle rod you can use a vacuum cap. It works well.
930cabman
post Mar 8 2025, 09:56 AM
QUOTE(ClayPerrine @ Mar 7 2025, 04:50 PM) *
great tip, I have not been 100% pleased with the kit I installed, partially because it's a tough area to access. I will try a rubber cap on the end and also some sort of "bushing" to minimize the sloppiness at the bracket/rod
zoomCat   Into the Tunnel   Mar 7 2025, 12:32 PM
zoomCat   Another view:   Mar 7 2025, 12:44 PM
NARP74   If only all that was accessible so you didn't ...   Mar 7 2025, 12:48 PM
zoomCat   A better shot of the hand throttle: And the bus...   Mar 7 2025, 12:50 PM
DennisV   Note that the bushing and nubbin on the end are m...   Mar 8 2025, 09:30 AM
jc73-914   cool ... thx for posting   Mar 7 2025, 12:54 PM
zoomCat   This shows the clearance for the shift rod through...   Mar 7 2025, 01:01 PM
Root_Werks   So clean! Looks great and yes, thank you for ...   Mar 7 2025, 01:16 PM
zoomCat   The small brake line at the back is a bit convolut...   Mar 7 2025, 01:17 PM
zoomCat   Another angle on the brake line:   Mar 7 2025, 01:18 PM
zoomCat   And the brake union, normally accessible from the ...   Mar 7 2025, 01:27 PM
technicalninja   Nicely done! The "attention to detail...   Mar 7 2025, 01:33 PM
worn   Nicely done! The "attention to detail...   Mar 7 2025, 07:36 PM
ctc911ctc   Really like the rubber bumpers on the stainless fu...   Mar 7 2025, 01:33 PM
zoomCat   I took a bunch of pictures from different angles, ...   Mar 7 2025, 01:37 PM
mlindner   Very nice Guy, that tunnel is a busy place. Thanks...   Mar 7 2025, 02:14 PM
ClayPerrine   A better shot of the hand throttle: And the bu...   Mar 7 2025, 03:50 PM
930cabman   A better shot of the hand throttle: And the b...   Mar 8 2025, 09:56 AM
Montreal914   Thank you for sharing this beautiful work! Ex...   Mar 8 2025, 12:01 AM
brant   Put mechanics wire into the tunnel before you inst...   Mar 8 2025, 09:53 AM
barefoot   Well, I got tunnel envoy :) :)   Mar 8 2025, 05:55 PM
SO.O.C914er   Thanks for sharing that is beautiful. Mine is such...   Mar 8 2025, 10:36 PM
morehills   Ahhhh, long seat belt anchor bolts. Mine was pr...   Mar 9 2025, 04:31 AM
- Lo-Fi Version Time is now: 3rd April 2025 - 01:10 PM
