> Dash / Instrument Lights Problem Unresolved
JimVG
post Mar 10 2025, 12:59 PM
I have researched this problem on this site, and I still cannot correct the issue of no dash/instrument lights on a 1973 914.
The Problem
When key is ON, and the headlight switch is in the ON position none of the instrument light bulbs illuminate. Turning the headlight switch dimmer has no effect. All fuses tested functional.
Testing Procedure
Using a test light that is properly grounded with the headlight switch ON and the dimmer turned to HIGH:
There is no power to headlight switch terminal 58a or 58b (Fuse #7 is functional).
Using a separate test wire with a working bulb connected to headlight switch terminal 58b and the opposite end plugged into an instrument bulb socket the bulb does not illuminate.
Using the same test wire connected to terminal headlight switch 56k (empty and has power) plugged into the same instrument bulb socket the bulb does illuminate (dimmer not functional).
Please advise.
Your time and consideration is appreciated!
emerygt350
post Mar 10 2025, 01:27 PM
I would suspect your switch dimmer is bad. I pulled mine and just bypassed the dimmer. New switches can be purchased I believe. If you pull the switch you can test it by sending 12 past the pot.
ClayPerrine
post Mar 10 2025, 01:52 PM
QUOTE(emerygt350 @ Mar 10 2025, 02:27 PM) *
The potentiometers are notorious about failing from age. Simple to bypass it and just wire the instrument lights to the park lights.
barefoot
post Mar 10 2025, 03:38 PM
QUOTE(ClayPerrine @ Mar 10 2025, 03:52 PM) *
For my 76, the instrument lights do come on with parking lights, key off.
BTW all are changed to LED's now I can see much better.
Barefoot
JimVG
post Mar 11 2025, 06:39 AM
QUOTE(barefoot @ Mar 10 2025, 04:38 PM) *
Barefoot
Thank you for your replies. I would like to bypass the rheostat. Is there any reason why I cannot connect to another blade on the switch that powers the parking lights? I believe that this would allow me to have instrument lights on when either the parking lights or headlights are on.
emerygt350
post Mar 11 2025, 06:56 AM
QUOTE(JimVG @ Mar 11 2025, 07:39 AM) *
Barefoot
I believe that is what I did as well.
I also put in all leds on the dash except the oil and gen lights.
- Lo-Fi Version Time is now: 12th March 2025 - 01:15 PM
