> Compression Ratio, Will I be able to tell the difference?
sdoolin
post Feb 7 2025, 04:42 PM
Rebuilding(ish) my 2056. On my first build I was able to achieve a compression ratio of very nearly 9.0:1. With this build, I am having to add .020 spacers below the jugs to get any measurable deck height in the jugs. I am calculating a compression ratio of 8.6:1.
Will I notice the loss in compression ratio?
sdoolin
post Mar 11 2025, 10:55 AM
She's alive, and running well(ish). Drove about 10 miles yesterday. Carbs are well synched, she idles well and takes throttle without drama. I think the timing is a little too advanced, I got a little spark knock on full throttle uphill climbing. I can fix that easy enough.
She doesn't feel quite as perky as she did before this build, but I haven't driven her in over a year, and I have new rings and bearings to break-in. I'm hoping after break-in she perks up a little more, hard for me to believe I can feel the difference between 9:1 and 8.8:1 compression ratio.
Found a pretty significant oil leak at both valve covers, which I hate. Just hate. I've ordered new bales and have fresh gaskets on-hand.
Thanks as always for all of the helpful responses to my questions. I'm sure I'll have more...
sdoolin   Compression Ratio   Feb 7 2025, 04:42 PM
technicalninja   You need AT LEAST .036 with cast and .040+ with fo...   Feb 7 2025, 05:38 PM
sdoolin   Measured deck height in the jug, with an .020 spac...   Feb 7 2025, 06:02 PM
Superhawk996   Sounds like you are playing with fire. Without se...   Feb 7 2025, 06:21 PM
sdoolin   Sounds like you are playing with fire. Without s...   Feb 7 2025, 07:26 PM
Superhawk996   Sounds like you are playing with fire. Without ...   Feb 7 2025, 07:30 PM
technicalninja   Measured deck height in the jug, with an .020 spa...   Feb 7 2025, 06:57 PM
sdoolin   Yep, I don't want this help. Y'all go buil...   Feb 7 2025, 07:27 PM
worn   Yep, I don't want this help. Y'all go bui...   Feb 14 2025, 07:12 PM
sdoolin   Yep, I don't want this help. Y'all go bu...   Feb 15 2025, 08:44 AM
sdoolin   I especially like the turd bit.   Feb 7 2025, 07:29 PM
sdoolin   Superhawk thank you for your reasonable response. ...   Feb 7 2025, 07:33 PM
Superhawk996   Superhawk thank you for your reasonable response....   Feb 7 2025, 07:44 PM
Jack Standz   Rebuilding(ish) my 2056. On my first build I was ...   Feb 8 2025, 03:05 AM
sdoolin   Rebuilding(ish) my 2056. On my first build I was...   Feb 8 2025, 07:35 AM
sdoolin   Bolted things up on one side of the engine today a...   Feb 8 2025, 12:37 PM
Superhawk996   0.100” clearance to the exhaust valve is startin...   Feb 8 2025, 01:43 PM
Jack Standz   Bolted things up on one side of the engine today ...   Feb 8 2025, 03:04 PM
sdoolin   Thank you both for the thoughtful replies. My orig...   Feb 8 2025, 04:32 PM
Superhawk996   0.140” - 0.150” clearance to exhaust valves is...   Feb 8 2025, 10:28 PM
sdoolin   Measured valve lift a bunch of times today. Worst ...   Feb 9 2025, 05:03 PM
sdoolin   I'll likely button this engine up this weekend...   Feb 14 2025, 02:27 PM
Jack Standz   Modified #2. Bolt transmission to engine. Remove...   Feb 14 2025, 04:41 PM
sdoolin   Modified #2. Bolt transmission to engine. Remov...   Feb 15 2025, 08:38 AM
930cabman   Have you checked crankshaft end play?   Feb 14 2025, 04:52 PM
sdoolin   Have you checked crankshaft end play? So I re-c...   Feb 16 2025, 04:08 PM
Al Meredith   Years ago when Len Hoffman was rebuilding heads he...   Feb 15 2025, 05:02 PM
worn   Years ago when Len Hoffman was rebuilding heads h...   Feb 15 2025, 08:49 PM
Superhawk996   No discernible crank end play is a no-go. Redo ...   Feb 16 2025, 04:30 PM
sdoolin   No discernible crank end play is a no-go. Redo...   Feb 17 2025, 08:09 AM
stownsen914   Separate from the crank end play, if you are askin...   Feb 17 2025, 08:15 AM
sdoolin   Separate from the crank end play, if you are aski...   Feb 17 2025, 01:16 PM
sdoolin   I have measured all of the shims I have on hand (6...   Feb 18 2025, 05:25 PM
sdoolin   So, I re-measured crank end play. Installed flywhe...   Feb 22 2025, 01:05 PM
Superhawk996   Am I looking for .004" thrust with all thr...   Feb 22 2025, 01:16 PM
sdoolin   Thank you Superhawk. Installed third shim, remeasu...   Feb 22 2025, 02:04 PM
Superhawk996   Thank you Superhawk. Installed third shim, remeas...   Feb 22 2025, 07:09 PM
Jack Standz   Add a cable from the negative side of the battery ...   Feb 22 2025, 02:24 PM
Superhawk996   I’m going to ask a question that I’ve assumed ...   Feb 22 2025, 07:17 PM
sdoolin   I’m going to ask a question that I’ve assumed...   Feb 23 2025, 09:20 AM
Jack Standz   It's a good idea to fill the oil filter with o...   Feb 23 2025, 02:51 PM
sdoolin   I have confused myself. It happens. Having re-in...   Feb 27 2025, 10:37 AM
Superhawk996   Follow the Haynes or factory manual to instill the...   Feb 27 2025, 12:15 PM
sdoolin   Follow the Haynes or factory manual to instill th...   Feb 27 2025, 04:02 PM
sdoolin   Engine went in on Friday. Easy peasy. After I pour...   Mar 2 2025, 05:23 PM
sdoolin   Could this be a faulty oil pressure sending switch...   Mar 3 2025, 10:30 AM
VaccaRabite   Could this be a faulty oil pressure sending switc...   Mar 3 2025, 11:35 AM
Superhawk996   If it were me I would not be starting the engine j...   Mar 3 2025, 12:53 PM
sdoolin   Installed my brand new oil pressure test gauge (Ha...   Mar 3 2025, 04:20 PM
VaccaRabite   Your pressure is high because the oil is cold and ...   Mar 4 2025, 06:20 AM
rfinegan   Woohoo glad you get the pressure...sounds like the...   Mar 4 2025, 09:03 AM
sdoolin   Yep, cold oil and running (expensive) Brad Penn 20...   Mar 4 2025, 09:10 AM
sdoolin   She's alive, and running well(ish). Drove abou...   Mar 11 2025, 10:55 AM
930cabman   She's alive, and running well(ish). Drove abo...   Mar 11 2025, 12:17 PM
friethmiller   @sdoolin , Congrats! Glad the build was succ...   Mar 11 2025, 11:54 AM
sdoolin   Moving on to some other fiddly projects. Oil press...   Mar 11 2025, 02:56 PM
- Lo-Fi Version Time is now: 12th March 2025 - 02:12 PM
