> FI Plenum Design, MS'ing my 2270
Tom Perso
post Feb 1 2005, 07:41 AM
Crazy from the Cold...
Hey Guys,
I am designing a MS system for my 2270 (163.86b cam, 48x38 valves, future Triad header). I am looking at running stock intake runners and possibly making a new plenum to run my Ford TB (probably from a 4.0L Exploder/Ranger).
Are there any "design guidelines" that should be followed when making a new plenum, such as a certian volume required for engine displacement?
Looking at space requirements, I see running the TB on top of the plenum is the only way to go. That, of course - begs the question... Is the stock 914 2.0L plenum a good starting point to modify to allow for the Ford TB?
Here are some pics for reference... I had a Bus 2.0L intake system to borrow, so I am basing my measurements and ideas off of that.
http://www.qtm.net/~persot/MS/
Any ideas, suggestions, etc, are appreciated!
Thanks,
Tom
Brett W
post Feb 3 2005, 11:10 PM
Tim, if you would be so kind as to take a tape measure and the external dimensions of the Porsche plenum. I roughed an estimate at 18x12x3, that should be about 10 litres. Close to my 2.5 rule.
However, it seems to me that just because engine parameters change slightly doesn't mean you have to start from scratch. I just don't see how you need a plenum that is 3-5 times bigger, and a TB that is 1.3 times bigger with an engine that is only about 13% bigger, even with the other changes you are talking about.
You are assuming the factory dimensions are correctly sized for a stock motor? My stock 1.6 litre Honda motor made 108HP from the factory at something like 6500rpms. It uses a 56mm TB. Although I believe the plenum volumn to be less that 3 litres though.
A smaller plenum will yeild good throttle response and drivability. The plenum should not have a flat bottom with defined corners. Airflow doesn't like corners. I would not bring the runners in at a 90 deg. angle like the manifold pictured in a previous post. Airflow does not like radical changes in direction. Notice how Porsche brought their runners out the bottom. You could do the same or you could bring them out of a rounded plenum at the angle where the corners should be.
Tom Perso   FI Plenum Design   Feb 1 2005, 07:41 AM
DNHunt   Tom I haven't really run my car enough to tel...   Feb 1 2005, 08:05 AM
maf914   Tom, Didn't Shad Laws build a plenum for a la...   Feb 1 2005, 08:19 AM
Jake Raby   With the cam that I set Dave up with, his plenum h...   Feb 1 2005, 08:21 AM
Tom Perso   Lots of good replies - thanks! I have seen Sh...   Feb 1 2005, 08:35 AM
DNHunt   Tom Don't give up on this. I believe there i...   Feb 1 2005, 08:46 AM
Tom Perso   I heard that running a new-unused fuel filter inli...   Feb 1 2005, 08:52 AM
914efi   SDS has an option for locking in a fuel value at a...   Feb 1 2005, 09:20 AM
Jake Raby   There may be ways to help the situation at idle, b...   Feb 1 2005, 09:21 AM
Tom Perso   ...   Feb 1 2005, 09:30 AM
Jake Raby   AThe idle is also inconsistent with an early openi...   Feb 1 2005, 09:53 AM
Tom Perso   Well, I've got the Mallory, so I can dink with...   Feb 1 2005, 10:11 AM
Brett W   Tom I will have to agree with Jake on this one. T...   Feb 1 2005, 12:00 PM
Reiche     Feb 1 2005, 04:13 PM
DNHunt   I think a more accurate statement is I got it to r...   Feb 1 2005, 04:56 PM
Brett W     Feb 1 2005, 06:56 PM
SirAndy   ...   Feb 1 2005, 07:24 PM
jwalters   http://www.914world.com/bbs2/html/e...   Feb 1 2005, 07:36 PM
Reiche     Feb 2 2005, 08:42 PM
SirAndy     Feb 3 2005, 12:17 PM
Tom Perso   Bringing this post back to life.... Any thoughts ...   Feb 3 2005, 04:29 PM
Bleyseng   For starters, lay a 1 gallon paint thinner can on ...   Feb 3 2005, 08:07 PM
TimT   Try to make a plenum along the line of this one. ...   Feb 3 2005, 08:22 PM
TimT   nuther   Feb 3 2005, 08:23 PM
Bleyseng   Brett, What are the valve sizes of that motor?   Feb 3 2005, 11:28 PM
Brett W
  Feb 3 2005, 11:41 PM
Brett W   My SOHC 1.6 has 29mm intakes and 25mm exhaust. No...   Feb 3 2005, 11:44 PM
Reiche     Feb 4 2005, 02:19 AM
Tom Perso   <...   Feb 4 2005, 06:01 AM
Brett W
  Feb 4 2005, 08:16 AM
Mark Henry   Not VW/Porsche but some tips on building a plenum ...   Feb 4 2005, 07:59 PM
Bleyseng   I just think that a inline 4 plenum design doesnt ...   Feb 5 2005, 12:15 AM
Reiche     Feb 5 2005, 12:41 AM
airsix     Feb 5 2005, 01:20 AM
Brett W   Turbo plenums are different. If you are going to ...   Feb 5 2005, 01:56 AM
cnavarro   Tom, I still have the original plenum that we fabr...   Feb 5 2005, 07:37 AM
Mark Henry   I'd like to see that too Charles....I'm st...   Feb 5 2005, 09:56 AM
TimT
  Feb 5 2005, 02:08 PM
Mark Henry   Holy fuch! http://www.914world....   Feb 5 2005, 08:38 PM
Brett W   Thanks Tim, I knew it was big but not that big.   Feb 5 2005, 09:21 PM
- Lo-Fi Version Time is now: 26th April 2025 - 02:56 AM
