gnomefabtech |
Member ![]() ![]() Group: Members Posts: 146 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None ![]() |
Hello all-
So, I'm finally able to turn my attention to the suspension on my car now that it's running. The car was hacked for a v8 when I got it and I have instead done my Hayabusa engine swap. I'll have to make a separate thread on the adaptor setup, but it's mounted north south and uses the original 901 trans. Dynos at about 300whp with turbo. 2k lbs overall weight. Narrow body. The PO added some crazy stiff rear springs on coilover sleeves and they need to go. Also the front is way too stiff. It's all 911 front suspension and brake parts. Questions: I'm thinking about 140# springs in the back, but how long a spring should I use. 14"? 12"? Helper springs? In the front I think it might have like 21mm bars, and that's way too stiff. Are normal 19mm 911 bars soft enough for a street driven 914? Or are there thinner 911 compatible bars? Thanks! |
gnomefabtech |
Does anyone know the motion ratio of the rear suspension? Seems close to 1:1.
slivel |
Old car....... older driver ![]() ![]() ![]() Group: Members Posts: 528 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California ![]() |
Does anyone know the motion ratio of the rear suspension? Seems close to 1:1. This is what I came up with: MR = Motion Ratio Rear MR(SQ) = 1.68 MR*MR d1 = spring to arm pivot d2 = hub to inner pivot 1.296296296 Rear Trailing Arm Motion Ratio d1 = 17.5 d2 = 13.5 914 trailing arm |
Lo-Fi Version | Time is now: 3rd April 2025 - 09:43 AM |
