Ron914 |
Member ![]() ![]() Group: Members Posts: 181 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California ![]() ![]() |
@emerygt350
I was asked my a member helping me with my high idle /vacuum leak problem how I currently have it hooked up .This is the diagram I am using . ![]() |
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,787 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
That was my first thought. But you don't have your advance hooked up right?
Best thing to do is cap everything now and slowly readd. Get it warm, then plug it all. Aar, retard, decel, etc. you can even check the mps by pulling the vacuum off the plenum while it is running and plug it with your finger. It will be rich but it shouldn't rev once you plugged it. If you have a vacuum pump you can just put 20inhg in the hose going to the mps and plug the plenum. If everything is plugged and it's still at 1400, grab a can of carb cleaner and start spraying around the plenum, the runner boots, and the injectors. If you don't get any change it has to be your timing (or possibly that combined with a lean idle mix). |
Ron914 |
That was my first thought. But you don't have your advance hooked up right? Best thing to do is cap everything now and slowly readd. Get it warm, then plug it all. Aar, retard, decel, etc. you can even check the mps by pulling the vacuum off the plenum while it is running and plug it with your finger. It will be rich but it shouldn't rev once you plugged it. If you have a vacuum pump you can just put 20inhg in the hose going to the mps and plug the plenum. If everything is plugged and it's still at 1400, grab a can of carb cleaner and start spraying around the plenum, the runner boots, and the injectors. If you don't get any change it has to be your timing (or possibly that combined with a lean idle mix). After we installed the motor my brother in law used his vacuum pump and verified the advance plate movement in the distributor but he does not live by me so I will go and invest in one . The vacuum off the distributor is no longer hooked up ,it is open to to air now. Once I got that part correct things got much better .You were correct in your previous comments about that and I had it connected wrong. I think I could be close but something is still not quite right. So let me make sure I understand . 1) get car warmed up with everything hooked up 2) then unplug all lines connected to the plenum and plug them. 3) Now re add those unplugged lines one at a time to the plenum looking for a change 4) while not running unplug the line going to the MPS from the plenum and put 20inhg on the unplugged line that goes to the the MPS and plug the plenum then start engine and check again? |
emerygt350 |
That was my first thought. But you don't have your advance hooked up right? Best thing to do is cap everything now and slowly readd. Get it warm, then plug it all. Aar, retard, decel, etc. you can even check the mps by pulling the vacuum off the plenum while it is running and plug it with your finger. It will be rich but it shouldn't rev once you plugged it. If you have a vacuum pump you can just put 20inhg in the hose going to the mps and plug the plenum. If everything is plugged and it's still at 1400, grab a can of carb cleaner and start spraying around the plenum, the runner boots, and the injectors. If you don't get any change it has to be your timing (or possibly that combined with a lean idle mix). After we installed the motor my brother in law used his vacuum pump and verified the advance plate movement in the distributor but he does not live by me so I will go and invest in one . The vacuum off the distributor is no longer hooked up ,it is open to to air now. Once I got that part correct things got much better .You were correct in your previous comments about that and I had it connected wrong. I think I could be close but something is still not quite right. So let me make sure I understand . 1) get car warmed up with everything hooked up 2) then unplug all lines connected to the plenum and plug them. 3) Now re add those unplugged lines one at a time to the plenum looking for a change 4) while not running unplug the line going to the MPS from the plenum and put 20inhg on the unplugged line that goes to the the MPS and plug the plenum then start engine and check again? Is your retard hooked up currently? That would nearly bring it down to 900 from 1400. I assume it is hooked up and doing its thing. You may want to play with that vacuum pump and the distributor. When you give it vacuum on the retard does it drop down to 900? Does the idle rise when you remove and plug the vacuum to the retard side of the can? I believe your list above covers all the bases. Hopefully it isn't a combination of things so keep an eye on any smaller changes. |
Lo-Fi Version | Time is now: 3rd April 2025 - 12:54 PM |
