theer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 691 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States ![]() ![]() |
I Race an LS2 powered 914 and an LS1 powered 944 with a bunch of other guys. The 944 has a Ford hydro-boost system in place of the stock vacuum booster (no room with the v8). Works great, if maybe a little touchy for my taste.
The 914 has upgraded Boxster brakes, but no power assist. I like it better, but everyone else prefers the assist. Has anyone figured out a way to get power assist for 914 brakes? We are pursuing an idea to use a Tesla brake module in the front trunk, with a stock MC (cap off all but one brake line) driving a slave cylinder which activates Tesla master. Even Better would be a electro brake module that’s hydraulically activated directly from the master… We are still brainstorming, so any ideas are welcome! Thanks! |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,477 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
Impressive fitting of a vacuum booster!
Make sure something like that will pass 'Safety/Technical inspection" for your class of racing. There is another problem with a vacuum booster that you will have to overcome. It's distant from your main vacuum source. I would use aluminum line for most of the run back to front. On an application of forced induction, you will need a fail proof check valve to keep boost out of the booster. Arnold Schwarzenegger couldn't depress the pedal under full boost. And, in both ITB and forced induction the vacuum source can be whimpy. I'd also install an "assistance" vacuum pump. Lots of options here. Many front drive 90s GM vehicles had a very workable electric vacuum pump assembly specifically for the brake booster. I'd still try the "old school" way that most posters have suggested first. You like that better anyway. What you like is the "feel" of a simple, non-assisted hydraulic system as it has more feedback. That Hydro boost in the 944 deadens this aspect a bit. If the car was "mine" I wouldn't provision it for others. Properly set up, the dual master set up should stop the car every bit as fast as a boosted set up and have less complexity making it more reliable. |
Lo-Fi Version | Time is now: 3rd April 2025 - 12:07 PM |
